Lower Trim on Windshield Slipped Off
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by montenido, Jan 24, 2008.
  1. montenido
    montenido A 2 Prius household
    23
    Calabasas, CA
    all. I was looking at my front hood today in the rain and noticed a space between the bottom of the windshield and the black plastic grill (air intake?). Looking at the front of the car (from the outside) it was on the left side. I hit a good-sized bird last night and maybe that knocked the plastic grill downward. There is certainly not much of an overlap between the bottom edge of the glass and the rubber lip. I was able to kind of push it back up, but I don't know if it will stay. This is the area where you can uncover your VIN under the hood. There is some sort of water catch basin behind the VIN door and I had several cups of water sitting in there. I got it all out and none seems to have made it where it shouldn't have, so maybe it is still weather tight, even with the bottom edge of the windshield exposed.
    Has anybody else encountered this problem? BTW, I am waiting for my stiffening plate arrive. Should be any day now.
    I love this site
  2. koa
    koa Active Member
    980
    45
    Hawaii
    I just had mine off to clean underneath since there are drain holes that get clogged up. There are clips/flanges that the windshield fits into on the windshield side and clips that snap in to the car on the front side of the cowling. Just be careful if you remove it to refit it since the rubber gasket is one piece and the cowling is two separate pieces. The rubber could tear. You also have to remove the two windshield wipers (14mm nuts). Just look (or put a piece of tape) at where they sit on your windshield before you can them off so you have an idea where to reinstall them. The windshield is water tight whether that cowling is on or not, but it does protect the fan blower intake from water.
  3. montenido
    23
    Calabasas, CA
    Thanks, KOA. That helps a lot.
    montenido
  4. richard schumacher
    7,664
    1,043
    United States
    Search the site some more. Someone once posted very thorough illustrated instructions on how to remove the cowl to clean out the water drains.
  5. Slartibartfast
    Slartibartfast Senior Fjord Architect
    61
    Twin Cities, MN
    Hobbit has these instructions up to explain how to install an EBH from the top without putting the car on ramps.
    Prius heat-efficiency mods
    The first part of the page is relevant to this thread, in how to take the wipers off and how to remove and replace the cowl.
