Lowering car?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by jivemastert, Jul 20, 2006.
  1. jivemastert
    jivemastert New Member
    28
    I was wonderin if ther was any place to get lowering springs fo my prius?!!!??!?!?!
    will lowerin it decrease my MPG!!!??!?!?
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
  3. jivemastert
    28
    <div class='quotetop'>QUOTE(efusco @ Jul 20 2006, 10:58 AM) [snapback]289353[/snapback]</div>
    How wuld that help tho?!?!?! i wuld think that since it is lower that there is more gravity on it and so it woud make the car have to struggle to be goin?
  4. efusco
    19,891
    1,192
    Nixa, MO
    Yea, more gravity... :rolleyes:
  5. jivemastert
    28
    <div class='quotetop'>QUOTE(efusco @ Jul 20 2006, 11:22 AM) [snapback]289376[/snapback]</div>
    oh word, that face cracks me up!!!!
    ok, gues i stil have a lot to learn!!!!!!! thanx bro!!!
  6. tnthub
    tnthub Member
    519
    Brunswick, Maine
    Airflow under a car is more turbulent and that creates more drag. Lowering a vehicle reduces the airflow underneath which can result in an increase in economy. A lowered vehicle also has a lower center of gravity which will generally improve cornering and reduce the risk of rollover. Plus, lowering a car often looks good, especially if using taller wheels and low profile tires and I bet the aerodynamic hubcaps would look sharp on a lowered vehicle.
  7. janetjanetbobanet
    janetjanetbobanet Junior Member
    52
    Wichita, Kansas
    Maybe I just spent too much time in an SUV, can't imagine lowering my Prius. The speed bumps are killing me now.
  8. cairo94507
    cairo94507 Active Member
    923
    36
    Auburn, CA, USA
    If "Master of Jive" is older than 12, I am going to be surprised. "More gravity"........come on, what happened to 7th grade science classes! Anyway, I do believe you might get a slight MPG bump by lowering the car a little. The TRD Sportivo suspension seems like you get about a 3/4" drop on average and likely a more responsive better handling suspension too. Lowering the car may reduce the wind turbulence under the car and increase mileage.
  9. mike_m
    mike_m New Member
    232
    <div class='quotetop'>QUOTE(Tha Master of Jive @ Jul 20 2006, 11:19 AM) [snapback]289372[/snapback]</div>
    As mentioned, I think you are trying to refer to the Center of Gravity?
  10. Godiva
    Godiva AmeriKan Citizen
    10,339
    Lower? You want to lower the car? Like it isn't low enough?
    Why not put in those low rider shocks so it can bounce and dance around.
  11. mssmith95
    mssmith95 Michael
    535
    Valencia, CA
    Actaully I though about lifting mine.
    Imagine pulling up to one of those huge lifted 4x4's on some dirt trail...giving a little honk...and then rolling off. ;)
  12. Cheap!
    Cheap! New Member
    1,157
    <div class='quotetop'>QUOTE(Tha Master of Jive @ Jul 20 2006, 09:50 AM) [snapback]289345[/snapback]</div>
    Hey if you find any hydraulic adjustable shocks let me know. I want to be able to lower my car at freeway speeds and raise it on a moments notice for speed bumps.
