Lowering Springs for '07 Prius Touring
Discussion in 'Gen 2 Prius Accessories & Modifications' started by vdubdcu, Feb 28, 2011.
  1. vdubdcu
    vdubdcu New Member
    Dallas, TX
    I have a 2007 Prius Touring Edition and ready to lower the car. I've been going back and forth at forums and merchant sites and finding conflicting information on what is compatible. What springs have you guys used or know of that can be installed in a Touring Prius? Coilovers is out because of budget... Please help. I'm ready to buy the springs.
  2. macmaster05
    macmaster05 Senor Member
    4,050
    728
    H&R springs work with the Touring. That is what I and Fingas use on our Tourings. H&R will not confirm this because they think the Touring is a station wagon. Nevertheless it works. After all it was made for the euro Prius which is essentially the US Touring. The drop is a nice raked stance 1.4"/0.7"
    B&G springs also work with the Touring but they are less reputable and 1" drop all around (not raked).
    Eibach springs will NOT work with the Touring. Their inner diameter bottom coil is too narrow for the Touring strut. I have called Eibachs R&D to confirm this.
    I was in your position 5 months ago so I know your angst and frustration but trust the homework I've done. Good luck!
    ebxgsxr likes this.
  3. vdubdcu
    vdubdcu New Member
    Dallas, TX
    Thank you macmaster05!!! Did you install a camber kit with your Prius?
  4. macmaster05
    4,050
    728
    Nope. I've driven 8000 miles with my springs now, and have had 2 alignments. My camber has never been a problem.
    However, on my most recent alignment my rear left toe was out of spec, which is not adjustable. However, I'm not worried. All I have to do is keep an eye on this, but I doubt it will need a custom alignment. I just gotta keep up with my tire rotations. :)
  5. darelldd
    6,057
    388
    Northern CA
    Hmmm. And I'm looking to LIFT the sagging rear of my non-touring '06. Any love there??
  6. vdubdcu
    vdubdcu New Member
    Dallas, TX
    I appreciate your help. I just ordered the springs from tirerack.com. Looking forward to the drop. Thanks again macmaster05!
  7. macmaster05
    4,050
    728
    Absolutely! :) Show us pictures when you're done! :D
    Hmmm....The best thing I could suggest is new OEM springs. Although I'm not sure if that's actually the cause of the sag. Springs should not sag very much. You might want to also look into new struts...that could be it too.
  8. darelldd
    6,057
    388
    Northern CA
    Yeah, so... mostly they sag because I overload. Unloaded, everything's great. But it is only unloaded when parked. Nothing is worn out or permanently "sagged" - I just want to keep the rear end level when I'm (over)loaded. I've added air springs to my other cars - impossible to do on the Prius, from what I can determine. :sigh:
  9. vdubdcu
    vdubdcu New Member
    Dallas, TX
    Success!!! I'm so happy with the results. There was a little gap in the rear setup; as indicated in previous threads but no big deal. Here are some pics...
  10. macmaster05
    4,050
    728
  11. toyotechwv
    toyotechwv Toyota Technician
    474
    251
    Princeton, WV
    How do they ride?
  12. vdubdcu
    vdubdcu New Member
    Dallas, TX
    It took a little getting use to the tighter ride... Not bad... Worth the upgrade/drop... Now planning the Front Strut Tower Brace and Chassis Stiffening Plate install...
  13. Luke H.
    Luke H. Junior Member
    United States
    So how much did the drop end up costing you when all was said and done?
  14. vdubdcu
    vdubdcu New Member
    Dallas, TX
    The springs were $230 from tirerack.com and a local mechanic installed it for $175. I kept the stock struts as my car had 40k miles on it and didn't want to put out more money for new struts yet.
  15. Daves09prius
    Daves09prius Active Member
    680
    161
    Gettysburg, PA
    I like the stance now that you've lowered it! Looks awesome!
  16. hunterxaz
    hunterxaz New Member
    28
    Salt Lake City, UT
    What did you do to your rims? They look like Gunmetal finish.
  17. LIPriusFreak
    LIPriusFreak Can I haz JDM?
    449
    34
    Long Island, NY
    thats what 16" touring rims look like w/o the fugly hubcaps hiding their true beauty
  18. vdubdcu
    vdubdcu New Member
    Dallas, TX
    I agree... :)
    Shelby profita likes this.
  19. Shelby profita
    Shelby profita Junior Member
    37
    Phoenix, AZ
    So I have a 2007 as well, with the base wheels. The title says base/touring. Are there differences in the suspension between the 2 trim levels. I have the package 4 with the figs and stability control..
  20. Shelby profita
    37
    Phoenix, AZ
    Doesn't seem to be any difference. My question was if the prius 2nd gen shared any suspension with any other vehicles.
