LRR tires and boat ramps?
Discussion in 'Gen 3 Prius Fuel Economy' started by Higgins909, Dec 25, 2022.
  1. Higgins909
    Higgins909 Member
    257
    58
    I'm just wondering about the potential future. Currently I have some oversized tires at 215/70R15, Yokohama Geolandar G015. They only have about 10k after 2-3 years. I need to visually inspect them, but I think they're like new. Grip and comfort is up but acceleration and mpg is down. This makes me want to go back to stock size and LRR tires. However I fear I will have lesser traction on the boat ramp.
    I don't know if LRR tires have a super great compound that it would be ok or if it's more about tread pattern. But would I then have problems going up the boat ramp? Does anyone know?
    Thanks,
    Higgins909
  2. CR94
    CR94 Senior Member
    2,642
    1,137
    Northwestern S.C.
    Are you taking into account the fact that the apparent loss of acceleration isn't entirely real, because the larger tires cause your odometer and speedometer to show less than actual distance and speed? On another hand, it's real to the extent it increases weight and aerodynamic drag.
    Any difference in traction is unpredictable, probably slightly more likely to be worse with LRR tires. That will depend on tread compound used by the relevant brands and models.
  3. Mendel Leisk
    38,726
    Theoretically that’s 1.35” lift and 7% reduction on revs per mile.
  4. CR94
    CR94 Senior Member
    2,642
    1,137
    Northwestern S.C.
    I meant "Are you taking into account the fact that the apparent loss of mpg and acceleration isn't entirely real ...?"
  5. Higgins909
    Higgins909 Member
    257
    58
    So my speedo went from showing 50 at 49mph gps, to showing 50 at 53mph gps. Went from reading 1 high, to 3 low... I think that makes sense. This brought my fuelly calculations to match my trip average mpg, that I reset every fill up. Each tire weighs about 10lbs more then stock size. So extra 40lbs rolling mass. Losing 8mpg is a 30% loss if I've done my math correctly. I don't think that would equal the 7%~mph difference?
    There is a video somewhere on YT where they put bigger tires on a Subaru Forester I think it was. It made it's 0-60 2-3 seconds slower or something.
  6. tonynap
    tonynap Member
    43
    37
    NY
    I stopped installing the LRR tires because of wet traction issues I was having.
    Higgins909 likes this.
  7. qdllc
    qdllc Senior Member
    1,370
    399
    For me, the issue with boat ramps is the crap that accumulates on them (if not maintained). LRR tires should have no loss of traction on a maintained boat ramp, and “good” tires will struggle on a poorly maintained ramp.
    Higgins909 and tonynap like this.
