Lug Studs
Discussion in 'Fred's House of Pancakes' started by Stevewoods, Jan 8, 2026 at 10:01 PM.
  1. Stevewoods
    Stevewoods Senior Member
    662
    1,147
    Seattle, WA
    The recent editon of Rock Auto's newsletter details "Lug Studs," which sounds to me like German weight lifters.
    But, no. Lug studs are an old technology coming back to haunt us. I am most miffed about how the studs usually make it more difficult to change a tire.
    At 67 I have enough trouble already.
    January Newsletter | Early EditionJanuary Newsletter | Early Edition
    Also, an amusing tale about changing plugs on a '68 Corvette.
    cyberpriusII likes this.
  2. futurist
    futurist Member
    42
    72
    United States
    2024 Prius
    No idea why those are coming back into vogue. Totally illogical esp in the context of changing a tire -- not every driver's a male w/ upper body strength, mfrs :cautious:
    I were just a little guy barely in school at the tail end of the musclecar era -- yes they had fans in HI in the '60s and '70s too (arguably the only kind of West Coast racing to make it over, drag racing).
    Friends of the fam had a '68 440 Six Pack Road Runner, a '70 LT-1 Corvette, a '69(?) International Scout, and a '68 396 Chevelle. So somewhat kiddo-marinated in the sound of lumpy cams, as no WOT around the kids or hell would break loose w/ their moms :p
    Later in life would meet a racing buddy whose father's a rather famous engine builder and tuner in WA, now for vintage Ferraris rather than big-block muscle. But learnt a lot about a culture I'd missed out on living here, our talks filling in the blanks behind what to me were basically all mystique :coffee:
  3. ETC(SS)
    7,211
    Dang.
    Just think....
    I've made all these trips around the nearest star and I've managed to avoid knowing what "lug studs" are or why somebody would KNOW what it is that they actually are supposed to DO.
    I'm presently able to DIY tire rotations on all of my vehicles, but it's getting easier....
    My 2020 Terrain is 'called' an SUV but I'm pretty sure that my pre-teen granddaughter could manage to loosen the lugs and swap those wheels out - without air or batteries.
    My '23 Pickup "may" have a different outcome.... :ROFLMAO:
    'lug studs'???
    I've finally aged out of that silliness......
    #3 ETC(SS), Jan 9, 2026 at 6:21 AM
  4. Mendel Leisk
    41,622
    Wheel bolts. VW uses them I’ve read. The hub projections could maybe help temporarily “hang” the wheel, assuming it has close-tolerance hub opening, while you rotate the wheel to align with the bolt holes.
    I’m a bantam weight, adopted a wheel-lifting trick:
    1. Wearing my steel-toes and a headlamp, with the car raised “just” enough for the wheel to be clear of floor when installed, roll/cajole the wheel into position, bottom tilting slightly closer, and stud openings roughly aligned.
    2. Sit on the floor facing the situation, with headlamp on, tuck my toes under the wheel around 4:30 and 6:30, lift wheel up with toes while steadying/guiding with hands, push onto the studs, get a lug nut started, and away you go.
    cyberpriusII and ETC(SS) like this.
  5. ETC(SS)
    7,211
    Work smarter - not harder...... ;)
  6. Trollbait
    12,571
    Hub + wheel bolt is half the connection points compared to hub + stud + lug nut. That meant less wiggle developing in the wheels. Which was something back when manufacturing had looser tolerances, and it's why the bolts are still used by some.
    As for why they are spreading outside traditional users, it's manufacturing costs; two vs three parts to assemble. Robots are lining up the holes in the factory, so that isn't an issue there.
    cyberpriusII and BiomedO1 like this.
  7. BiomedO1
    BiomedO1 Senior Member
    3,774
    1,961
    SacTown, Ca
    Make sure you teach those kids how to "step on the lug wrench", for those peculiarly tight lug bolts. That seems to be a dying art form. When I was reviewing, how to change a tire with the kids, none of them knew or could figure out how to bust a tight lug nut off. Of course I get the snarky, I'll just call AAA.:( No wonder they can't figure out anything for themselves.......:whistle:
  8. Mendel Leisk
    41,622
    If you need to step on the wrench it’s time for a new tire shop. Or DIY, if that’s what it takes.
    definitely do the stepping before raising, just enough to get them turning.
    BiomedO1 likes this.
  9. cyberpriusII
    cyberpriusII Maybe it was the roses
    1,157
    1,807
    Mars Hotel
    Stepping? For me?
    It's more like hopping up and down on the end of the tire wrench. Even then it's often a painful process for my knees.
    And getting them back on usually means more jumping to hit proper torque. About 78 ft-lbs...
    kris
  10. Mendel Leisk
    41,622
    Tesla mdel 3 lug nuts are 129 ft/lbs. When I "give them the beans" with my trusty/rusty, Porter-Cable corded impact, it just kinda cogitates, for about a second, before it starts loosening. It's rating is a lowish 450 ft/lbs though.
    #10 Mendel Leisk, Jan 9, 2026 at 12:17 PM
  11. Trollbait
    12,571
    We once ended up doing the bouncing, and ripped the lug off:eek:
  12. bisco
    52,066
    i like the pilot pins, seem like a good idea if you're stuck with studs
  13. cyberpriusII
    1,157
    1,807
    Mars Hotel
    And, who here dealt with the infamous Prius wheel fusing to the car issue?
    Mini-sledge, bad words, calls to the mental health lifeline. Nothing worked until I think it was Patrick Wong suggested l loosen lugs a smidge, drive at snail speed, slam on brakes. Before reinstall wire brush wheel and slather on ?white? grease? I don't recall.
    kris
    #13 cyberpriusII, Jan 9, 2026 at 2:16 PM
  14. Mendel Leisk
    41,622
    Anti-seize paste applied thinly with an old toothbrush works good.
    my drill with rusted-on wheels (haven't had any in a while though), was (on a concrete slab) raise till the wheel was just clear, remove all lug nuts except one at 12 o'clock, just on about three threads (to restrain wheel, if-and-when), place 4x4 wood block against inside face of tire, set full-size sledge hammer about 3 foot back swing across the concrete with a good amount of effort. Can take 2~3 tries, with escalating violence. :)
    (With every parenthesis I'm feeling Steve's editor's withering disapproval.)
    #14 Mendel Leisk, Jan 9, 2026 at 2:29 PM
