luggage compartment question
Discussion in 'Gen 2 Prius Main Forum' started by ghirl, Jan 5, 2006.
  1. ghirl
    ghirl Junior Member
    36
    Newton, Massachusetts
    I just picked up my sliver pkg5 06 Prius yesterday. I have a couple questions. In the luggage compartment does anyone have a cover over the tire tools? When I lift up the cover to the compartment the tools are just sitting there. Just checking if I am missing something. Also is there a way to make the cover to that compartment so that it doesn't bend in half? It makes it hard to access the entire compartment easily. Any tricks. Thanks.
  2. hyo silver
    hyo silver Awaaaaay
    15,232
    1,562
    off into the sunset
    Ghirl. Congratulations on your new baby.
    Yes, the tools just sit there exposed. If you prefer, a carpet or rubber mat could be cut to fit in that space.
    The cover bends so you can access stuff underneath, without having to move the stuff you have on top. I've found this very handy when the car is packed. Again, this could be changed if you wish, but I suggest you try it for awhile and see if you get used to it.
  3. nwprius
    nwprius Member
    227
    35
    Lacey, Washington
    There is a rod on the left side to hold up the second half after you fold the first half back. Thus the entire cover is open.
  4. CedricMordrin
    CedricMordrin New Member
    42
    Yeah, I like the dual hinged approach.
    What I want to know is has anyone found a good solution for dividers. There are slits in the walls for them. But I've not seen them mentioned or for sale anywhere...
  5. DocVijay
    DocVijay Active Member
    1,455
    Tampa, FL
    Try here:
    http://sigmaautomotive.com/jdm/prius/prius0405.php
    About half way down the page are the Under Deck Partition Plates for $39.
  6. maggieddd
    maggieddd Senior Member
    2,090
    Boston
    sigmaautomotive sells the dividers
  7. maggieddd
    2,090
    Boston
    DocVijay beat me
  8. richard schumacher
    7,663
    1,037
    United States
    ghirl, do you use the window-shade tonneau-cover thingy? After two years I haven't yet needed to store anything in the space under the hard cover.
