Luggage lock for charging cable
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by krishkal, Apr 12, 2012.
  1. krishkal
    krishkal New Member
    Fremont, CA
    Thanks to the other thread, I noticed the hole in the charging connector. It seems to be made to fit a standard luggage lock. I happened to have an old one laying around, and it is perfect, as seen in the picture below:
    Of course, it won't stand up to a real "bad guy" with a bolt cutter, but none of the solutions will. It is a deterrent, and works fine as such! And, no modifications are needed, and it has a combination, so you won't lose the key.
  2. SimiPrius
    SimiPrius Member
    247
    60
    Simi Valley,Ca
    Master Lock - 4680DNKL is what others have recommended...and you can use it on your luggage when you travel.
