"Lunging" while braking with weak traction
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Frogerelli, May 22, 2013.
  1. Frogerelli
    Frogerelli Junior Member
    38
    Fort Smith, Arkansas
    As in lunge.
    I first noticed this about two months ago (I bought the car three months ago) when I was braking on straight, level ground, but it was raining and I was crossing railroad tracks while I was braking. Fortunately, no one was in front of me. The sensation wasn't merely a loss of braking traction (sliding), this felt like a momentary, power mode/full throttle thrust. Straight forward. At the time, I was clearly caught off guard, but the effect/sensation was quite momentary, almost as if someone had mildly rear-ended me.
    Braking after that moment was normal.
    The effect didn't replicate itself again until recently when I was braking for a stoplight on a sh-tty concrete road where the sections have a slight tilt to them. This is exaggerated of course, but the sections are like this: ///////, meaning there is a 1/4 to 1" dropoff from one section to the next. there is one particularly pronounced dropoff close to the stoplight. The effect happened again and it is reproducible. Again, it is not merely the sensation of taking your foot off the brake, but one of a momentary punch of acceleration. No appreciable sound of higher engine revs.
    Anyone else experience this?
  2. matt b.
    matt b. Member
    251
    60
    L.A.
    is not happening to me but the year of your Prius there was are brake recall I would suggest that you take it in to the dealer. you could also contact ur nearest toyota dealer and give them your vin and they can see whether or not your car is one that has been recalled hope this helps.
  3. Les_PL
    Les_PL Active Member
    317
    248
    Gdynia, PL
  4. Codyroo
    Codyroo Senior Member
    1,826
    515
    Pleasanton, Ca
    This is a known "experience" with the Prius braking system and there are a number of threads discussing it.
    Prius Brake Problem - CONFIRMED BY TECH | PriusChat
    This typically happens under light braking when are just using regen braking instead of regen brakes AND the disc brakes. The car senses that your wheels are slipping and reduces braking to prevent a skid. The sensation feels like you are surging forward.
    I've had this happen to me once or twice and it gives a nice adrenaline rush!
  5. car compulsive
    car compulsive Active Member
    741
    274
    Michigan
    Yep, one of the quirks of this car - along with the loss of most thrust when you take off on gravel or ice and wheel spin is detected. Give yourself more braking distance and DON'T lift your foot off the brake and try to pump them (like us old guys were taught back when Moses was a boy).
    spiderman likes this.
  6. Lynette
    Lynette New Member
    Yes....several times when I have braked while going over an uneven surface or bump I have felt a lunge forward. I thought I was imagining the movement because it is only for a slight moment. After several observations I decided to come on to this forum to see if anyone else has had this problem. Has anyone mentioned this to the service department at the dealer?
  7. 32kcolors
    32kcolors Senior Member
    5,683
    953
    124
    Redondo Beach, CA
    It's a common and normal characteristic of regenerative braking that you simply need to get used to.
  8. Frogerelli
    38
    Get used to it? I'm resigned to it for this vehicle, but every one of us should not be.
    A response time of 1/100th of a second is easily achievable. That is what was the standard response time for a 2004 Lexus active suspension. There is no reason the technology of this response time (or much faster) should not have trickled down in 6 years to be applied to regenerative/conventional braking. It's the same corporation, after all; there shouldn't even be any costs of licensing the technology.
    Toleration begets lack of innovation.
  9. Frogerelli
    38
    30 mph equals 44 feet per second. Think how long it takes for the the system to switch and remember that it always happens in sub-optimal situations. Do you have 22-33 feet to spare?
  10. hlunde
    hlunde Member
    419
    74
    Actually, I believe that the initial sensation is due to a purely mechanical effect -- braking torque being applied at the transaxle output shaft through a mechanical differential, so if one wheel slips, the other cannot generate torque. At this point the ABS kicks in. A positive aspect is that the driver's foot is already on the brake pedal, so the application of additional pedal force (thus transitioning to friction braking) is rather swift. An MG on the rear wheels would readily address this issue.
    That said, I am continually aware of the regenerative braking effect and always brake more cautiously with the Prius. The gear whine from regenerative braking is my key.
  11. Mide
    Mide Junior Member
    Yup I've had this happen to be as well before I read about it on the forums. I was lucky that I gave myself enough room after the pothole to have distance from the car in front of me or else I would've rear-ended him. Just got to be careful.
    I looked up my VIN number with some recall a while ago but it can up empty so I doubt Toyota will help out any.
  12. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Doesn't happen if you get the recall done. That was the recall done about a year ago.
