"Lurching" forward on braking over bump problem anyone?
Discussion in 'Prius v Main Forum' started by NavySeal, Dec 21, 2012.
  1. NavySeal
    NavySeal New Member
    27
    17
    New York City
    This is an issue when I brake over a small bump or pothole. It lurches forwad and I feel like I have lost control of the brakes and we are about to crash into the car in front of me. Seems like this is an issue with other Prius years but I thought this was fixed with the v. Anyone else having this problem and what should we do about it?
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Yes, just about everyone. Common feeling when transitioning from regen braking to friction braking (in a loss of traction situation). You will get use to it. BTW, don't rush an intersection with a Prius.
  3. Paradox
    29,110
    8,591
    201
    2014 Prius v wagon
    The car doesn't lurch forward. It's a momentary loss of braking essentially, very very momentary during transition from regen braking to friction. They've fixed it to where it is shorter but not gone.
    51,155
    just keep your foot on the brake, you'll stop eventually.
  5. Soylent
    Soylent The v isn't a station wagon! It's just big boned
    443
    Fort Lauderdale, Florida
    2013 Prius v wagon
    It may also be traction control. If one wheel hits a bump and loses a little traction for that split second, the traction control will pulse the brake and give you a sensation that you've stopped braking (almost like a free-fall feeling)
  6. El Cuajinais
    El Cuajinais Junior Member
    31
    2013 Prius v wagon
    I'm a new Prius v owner and experienced this once so far. Glad to know it is normal.
