:mad: VSC got me in an accident today
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Maui, Aug 20, 2009.
  1. Maui
    Maui New Member
    Madison, WI
    As I have seen discussed in other threads, we have noticed that hitting a bump while braking seems trigger VSC to disable braking for a moment.
    Well, tonight with the help of our trusty VSC I was involved in a low-speed accident in which I rear-ended someone. Though I admit I was late in applying brakes, there still would have been *plenty* of time to stop before hitting the car in front of me. However, the VSC system kicked in-- and this time I don't even recall hitting a bump. Rather, I think since it was wet and I hit the brakes so suddenly, it caused some slippage which triggered the VSC-- and that was the end of that. For the next 2 full seconds (*not* exaggerating), I was getting virtually no braking despite the fact that I was pushing the pedal through the floor. What *seemed* like an eternity later we until finally hit the car ahead of me. BTW, our windows were down and I certainly would have heard skidding if that was the case. And, yes the VSC light was flickering the whole time so I'm sure it was the culprit.
    Fortunately, I was only going about 10 mph when I hit the brakes (maybe 5 when I hit him), so the damage was limited mark on his bumper (waiting to see if he's going to milk me for this).
    So for starters, I'm frustrated as heck with VSC. The dealer says I can pay $110 to have them check the computer for error codes, but its my impression that that's just going to be wasted money due to my experience and reading that, insanely, Toyota engineers apparently feel periodically removing my ability to break is a worthwhile "safety" feature and that it cannot be disabled.
    Second, the dealer tells me there's no way to get data from the data recorder. Is that really the case? I would love to have any data the recorder might have if this guy tries to take me through the ringer for the scuff mark on his bumper. It sure would be nice to prove how I hit the brakes in what should have been plenty of time (though I'm not sure how much good it would really do me). Does anyone know a way to get that data?
  2. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    that's not VSC.. that's traction control. trac flickers.. vsc beeps.
    i have never heard of someone recovering data... good luck with that.
    glad to hear you're ok. welcome to priuschat.
  3. Maui
    Maui New Member
    Madison, WI
    Okay... is that different, in turn, from ABS? Whatever happened to pulsed braking? There was certainly no pulsing of the brakes going on. What's the point of ABS if traction control is just going to disable braking altogether?
  4. Tideland Prius
    16,445
    Umm.. I think you're jumping to a conclusion much too early. V8Cobrakiid already explained one part. I'll finish the other.
    ABS went off. You were braking at full force (Brake Assist would've been helping you as would Electronic Brakeforce Distribution) which is standard on most new cars (Brake Assist not available on subcompact cars like the Yaris and only available on some compact cars like the Corolla and Civic Hybrid).
    May I strongly suggest you go to an empty parking lot and see how the various systems work. You will not feel a pulse when applying full braking with ABS on a Prius (or any Toyota hybrid for that matter). Given that you're in WI, I'd also try it in the winter so you know how VSC works (and hear the beeps) and the system's capability.
    Edit: and you can't get at the data recorder unless requested by the judge to allow the police to access the data. If it's a scuff on the bumper, it'll be a cheap repair. If anything, the data recorder may work against you (because you braked too late or not hard enough)
  5. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi Maui,
    Its going to be hard to descern its truely an ABS fault, or if the road had a slick spot when the brakes tried to regrab the road. Weather around here has been very dry until recently. In such situations the gunk on the road mixes with the first water on the road and makes a very greasy slick surface. And this usually is worse near where cars are stopped or approaching a stop. Because of the stuff that falls off cars stopped at those locations during the dry spell.
    In Madison, your going to need to get ready for wet leaf season. This issue will be worse then.
  6. Maui
    Maui New Member
    Madison, WI
    I've had the Prius for 3 years -- I'm not new to it. Yes, its barrels of fun in the winter to whip around corners with with the VSC beeper screaming at you.
    I'm not arguing that I didn't notice he was stopped as soon as I should have-- my bad on that account. But it certainly should have been plenty of time to stop in any car that a computer chip didn't override me.
    Have you never had the experience where ABS/VSC/TractionControl triggers when you hit a bump while braking and then prevent you from braking afterward? I'm not arguing that this "feature" is intentional-- but I think its dangerously oversensitive. Without it, I could have stopped at least 2 car-lengths back from where I did. Probably 1 car length back on ice.
    So who reads the data for the police? Why should I need a judges permission to access data from a product I own? Granted, I'm guessing it may not be worth the price whoever it is that can do it would charge, but it seems pretty wrong that someone can install technology on a product to monitor things the person does, but then could legally prevent that person from accessing the data.
  7. Maui
    Maui New Member
    Madison, WI
    If you think that's bad here, you should visit Portland this fall.
  8. Tideland Prius
    16,445
    What about tyre treads? Are your tyres close to worn?
    Yeah I've had it go on numerous times...manhole, railway tracks. It's the rainy west coast. I know it'll happen so I don't brake or accelerate hard when I go over those objects. I'm sure the police have databox readers (not the local police but whatever you guys have higher up.. state patrol? or does the local police do everything?
    the blackbox is not meant for court cases. It's meant for the manufacturer to record data in an accident so that it can go back and improve safety (like seatbelts, brakes, airbag deployment etc etc). That's how we got advancements in airbag technology (dual stage and multistage front airbags, front occupant detection sensors etc)
  9. Maui
    Maui New Member
    Madison, WI
    We replace the tires last year with Goodyear Assurance ComforTred tires (about 8 months ago). Goodyear gives them a "8" for wet traction vs "6" for the factory installed Integrity's (wish we had gone with a different tire or that the FuelMax was out when we replaced the tires-- we definitely noticed a mpg hit )
    ... and maybe they could use my blackbox data to advance their "traction control system" (I use the term very loosely) as well...
  10. djasonw
    djasonw Active Member
    960
    121
    Coconut Creek, FL
    Maui (I love that island btw), I am very aware of the situation you are referring to. I live in one of the outer boroughs of NYC. The roads around here are awful. I tell you, if gas was 75 cents a gallon I'd have an SUV because I feel I am doing harm to my Prius driving on such horrible roads. Anyway, the point I am trying to make is that there are instances where if the road surface is uneven and bumpy you can momentarily lose braking because all four wheels are not in contact with the surface at the same time. I also think that to mitigate this from happening Toyota should have an IRS in the rear. (anyone know if the 2010 has IRS????) The way these systems are designed makes this type of phenomenon happen in any vehicle. I had a Subaru WRX that did this more often than the Prius. Even with this type of thing happening, it has not ever compromised my safety. I think that in your situation it is due to the fact that you braked too late. Luckily it was nothing major and thank goodness you're ok.
  11. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    From the description, this sounds like simple loss of braking, not anything relating to ABS or traction control. It's a common mistake to assume braking would be better without the new features, when in fact there is no reason to assume that is the case. Without a controlled study, you have no way of knowing what the braking conditions were like. I suspect you hit a bad spot, and combined with late braking, you were going to hit the car in front with or without ABS or traction control.
    Tom
  12. Tideland Prius
    16,445
    djasonw, no IRS. It's still a torsion beam
  13. Maui
    Maui New Member
    Madison, WI
    Okay, well, for argument's sake, lets leave out my incident today and talk about the lack of braking after hitting a bump since many have experienced that. What I don't understand is why the car apparently removes braking from all wheels at once when one of them loses traction. It seems like it would be straight forward enough for the car to identify which wheel or wheels are slowing faster to the others and cut braking there (and for only a split second).
    What seems downright dangerous to me is the fact that the car seems to immediately cut brake power to all wheels once one of them slips and then seems to double and triple check that all wheels are rolling in sync before attempting to re-apply any brake power.
    Don't get me wrong, I love our Prius. It's a great product. I just am annoyed the philosophy that apparently goes into the engineering of the traction control. If in doubt, the thing should brake where it instead seems to go to great lengths to be sure it's not going to skid before breaking while in the meantime it has coasted well beyond where a skid would have taken it. I know this is subjective (outside of the data hiding in my blackbox), but I've been driving for a couple decades now and I think I have a pretty good idea about how a car should be able to handle.
    I agree that I should have not been be in a situation where stiff braking is required to avoid an accident, but it seems to me the purpose "safety" is to increase my chances when I get into a bad spot, not decrease them. I guess if no one knows of a way to get data from my black box, you'll have to take my word that a 1980 Chevy Suburban with bald tires and no active "safety" systems would have easily been able to stop.
    BTW, the light turned green, traffic started moving, I was distracted by my wife handing me a snack, I looked up and saw the car ahead had stopped to turn left... we've all done it. I swear, I'm not a monster.
  14. NoMoShocks
    NoMoShocks Electrical Engineer
    1,292
    82
    Camas, WA
    That's the point, If not for the ABS, you would have heard skidding, and your braking would have been even less effective. You will feal a little shuttering sensation in the ABS breaks when they are doing their job, which is to stop the car as quickly as posible on the slick pavement that would otherwise lead to a four wheel skid with practically no stopping power at all. The computer modulates the braking at each wheel to just the point before brakes would lock up, and it feels like brakes are slipping, but in reality, they are stopping you as efficiently as posible with no grip at the tires.
  15. fuzzy1
    10,335
    From my (weak) understanding of these data recorders, I'm not convinced that it contains anything. With no airbag activation and the low speed you describe, it seems likely that your 'collision' was below its trigger threshold.
    My Prius experience is still much too short to comment on your brake anomaly. I've triggered BA exactly once, and ABS / TRAC / VSC not at all. As soon as the unseasonably dry weather breaks, it'll be time for a few tests.
  16. Flying White Dutchman
    4,376
    313
    what happend was dat abs kicked in and slow the car down a lot faster then without
    if the abs system did not came on the wheels would have blocked and you would hit the car in front of you a bit harder then you did now.
  17. ursle
    ursle Gas miser
    1,049
    192
    NH
  18. Maui
    Maui New Member
    Madison, WI
    All I can say is I was there and you weren't. If there was any sort of deceleration after the "traction control" kicked in, it sure wasn't perceptable to me. We we coasting-- and for a long time.
    I've done more searching and found this post among others which may as well have been my description of my accident except that we hit a Jetta, not an Impalla and (thankfully) only left a scuff mark not a several thousand dollar repair.
    I called the police today and asked about the blackboxes. He told me that many automakers such as GM make equipment available to retrieve the data, but that Toyota does not. He said (as someone previously stated) that when there is a crash that results in a death, they request the data, but that subpoenas need to be issued, that it all goes through Toyota corporate and that it is a long and difficult process even for them. Also, he said that even if they did make the equipment available as GM does, it would still cost multiple thousands of dollars. Basically, he said, the only time it would be worth it is in a court case where a lot more is at stake than a scuffed bumper.
    Basically, its the principle of the whole issue that gets under my skin. By preventing me from accessing the data, Toyota can easily refute (just as Dutchman and others have done) that their traction control in any way can contributed to my accident or any others. Maybe this is all fixed in the 2010 model, but I still prefer Toyota be forced to address this issue-- what if the Jetta I hit had been an old lady?
    I think this weekend I'm going to try to set up a test comparing the stopping distance of my Prius when hitting the brakes hard at about 10 - 15 mph on a bumpy road vs a friend whose car has standard, pulsing, anti-lock brakes. I'll let you know how that goes and maybe even will post YouTube video.
  19. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    I don't think VSC is what happened to you. That only kicks in while making a turn or taking a corner, if there is understeer or oversteer
    When the Prius is braking normally, regenerative brakes are used. If a single front wheel slips, there is a slight pause while the brake system has to switch from regenerative to friction brakes. See this diagram
    The Prius does have brake assist, and on dry pavement it works well. However, on wet pavement, or even worse, snow/ice, the system appears to become easily confused as it transitions from max friction brakes to ABS modulated brakes
    The absolute worst situation to have ABS brakes is on a gravel road. A vehicle that can lock up the wheels will stop MUCH sooner on a gravel road, than an ABS equipped vehicle
    I've played with my Prius brakes in empty parking lots and deserted side roads. As with most ABS vehicles, it's easy to confuse them if just one wheel happens to hit ice or a slick spot, or if there is a rough surface like rumble strips or washboardy gravel road
    I've never felt my Prius brake pedal pulsate when ABS is engaged. As my FJ Cruiser also has electric assist power brakes, I've never felt the brake pedal pulsate in that vehicle either
    Speaking of my FJ, much like the Prius, once a single wheel loses traction while braking, ABS engages and the brake pedal sinks. Hitting a manhole cover or a pothole just right can be exciting. Though my 2000 GMC Sierra was much worse in that regard
    At least with the FJ, once I shift into 4H, the VSC is dumped, and the TC and ABS are detuned. Shift into 4L, the TC and ABS are also dumped.
    But under normal conditions, in 2H, my FJ has far better behavior from the ABS and TC than my Prius did. The VSC cuts in very early, but that is due to the FJ being a high profile, high center of gravity SUV
  20. Presto
    Presto Has his homepage set to PC
    1,326
    24
    Vancouver, BC
    I suspect that the road was really really slick. Looking at the weather history of Madison, it looks like it hasn't rained for almost a week, and yesterday was the first splash of rain in 6 days. That first shower after a week of dryness will result in extremely poor traction.
    Us Vancouverites are no strangers to rain, but the first rainfall after several weeks of glorious sunshine brought traffic havoc. It was very easy to break traction. I could floor it while the Prius was moving at 25MPH, the front tires slipped.
