Maddening Creaking from Back Seat
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ingyaningya, Sep 9, 2016.
  1. ingyaningya
    ingyaningya Junior Member
    70
    17
    Miami
    Lately there is been a really predominant creaking sound coming from the backseat area whenever there is the slightest turn or bump in the road. Lately it's been getting worse and worse, and it's obvious that it's coming from the backseat area, I just can't pinpoint where. I'm pretty sure it's not the shocks because when I push down on the car there is no sound, and when I jump around in the backseat I can't reproduce the sound either.
    When I have a lot of junk on the seat, the creaking seems to go away slightly, but when there is nothing on the seat, the sound is extremely noticeable. Does anyone have any idea what the sound is?
    51,732
    try taking the seat out and see if it's still there.
  3. DonDNH
    DonDNH Senior Member
    1,711
    654
    Nashua, NH
    Four Touring
    Is the seat back securely latched?
  4. fotomoto
    fotomoto Senior Member
    5,632
    3,809
    So. Texas
    Interior creaking sounds commonly come from plastic trim.
    Exterior creaking generally comes from worn out suspension pieces.
    #4 fotomoto, Sep 9, 2016
  5. andrewclaus
    andrewclaus Active Member
    993
    326
    Golden, CO
    Is it definitely from inside the cabin? If so, get someone else to drive and sit back there and listen around. And as mentioned, at least flip the seat bottom up and seat backs down for cargo storage, see what changes.
    There's more to the suspension than bouncing the shocks. There are some bushings back there that might creak under driving load.
  6. Kenny94945
    Kenny94945 Active Member
    845
    421
    Sausalito
    2016 Prius v wagon
    Noises can be tricky.
    One thinks it is coming from left rear yet is coming from right front.
    The noise may even be from the under carriage.
    I assume you checked the seat mounting bolts first, and I like the remove the seat idea suggested above. That would confirm the noise is in the seat.
    Yes, plastic trim in the rear seat lower area is notorious for causing a noise...do a search.
    Also, repeating good advise and someone ride in the rear and help locate the noise.
    There are noise, vibration tools to help hunt yet typically not inexpensive other than a stethoscope (yes seriously).
    So......happy hunting.
