Mag Wheels more efficient?
Discussion in 'Prius v Accessories and Modifications' started by JCWPV, Feb 7, 2015.
  1. JCWPV
    JCWPV New Member
    Las Cruces, NM
    2014 Prius v wagon
    I bought a 2014 Prius v, series 3 a couple of months ago. When installing the mud guards, I found 16" mag (aluminum) wheels on the car under the factory plastic wheel covers! Factory error or maybe they ran out of steel wheels. Question: Which is more aerodynamic and which gives the best brake cooling? Wheel covers on or off? Any factual data available on this? Sources for the hub caps to go with the mag wheels?
  2. fuzzy1
    10,172
    I don't remember any 'v's or Liftbacks coming with steel wheels. Only some 'c's do.
    For best MPG, leave the covers on. They add some tiny increment too small for you to discern, it matters only to ensure rounding up to the intended EPA score.
    For appearance, do as you please.
  3. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    If you want to take off the plastic wheel covers you can purchase "hub caps" for the hole in the centre of the wheel either online, or from Toyota. The GII hub caps work fine. I'm using them. I removed the covers because they hold dirt on the wheel. Dirt plus road salt equals damaged wheel finish.
    As far as efficiency goes, as posted above I doubt you could measure the difference in aero effects, but you -can- measure the difference caused by weight. The wheel covers are heavy. The hub caps are not. Of course, if you replaced the tyres with heavier ones then all bets are off. ;)
  4. JCWPV
    JCWPV New Member
    Las Cruces, NM
    2014 Prius v wagon
    Fuzzy and David:
    Thank you for your answers. I would now guess that the full wheel covers may have been required to get the EPA rating since they must cost more that the small hub caps for the mag wheels and maybe the aluminum/mag wheels weigh less than the steel wheels.
    Thanks again.
  5. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    Yes, and rotating mass hurts fuel economy more than mass in the body, so if you are going to save weight, the tires and wheels makes sense. (The brakes would make sense, except we need them to be able to absorb all the heat we might ever need to expose them to, so be very conservative lightening the brakes)
  6. Eric "v"
    Eric "v" Member
    229
    44
    'Vegas, NV, Baby
    2013 Prius v wagon
    I not only removed my wheel covers but soon after I purchased NEW WHEELS (& tires).
    I got 17" ENKIE RPF 1 wheels which are the lightest available that matched the 5 Model size, and Yokohama YK 580 tires in 215/50/17.
    The plastic wheel covers look cheap and for the tiny "extra mileage" are not worth the weight.
    With much lighter wheels I have:
    1. less starting rolling weight to overcome
    2. less rolling weight for braking
    3. less unsprung weight for more responsive handling
    And then there's the undeniable "custom coolness" factor. ;o)
  7. mikefocke
    3,701
    1,649
    Sanford, NC
    No idea.
    Didn't like the look of the plastic hubcaps. Took them off and found 16 inch "mags" and bought ebay plastic center caps.
    Impressed with how clean the wheels have stayed, haven't cleaned them in 21k miles.
    Never did anything to the wheels on any of my previous cars dating to 1960.
  8. CR94
    CR94 Senior Member
    2,642
    1,138
    Northwestern S.C.
    3½ pounds for my four of them.
    My compromise:
    Keep them off in local driving, which involves a lot of stops, starts, and hills, generally at relatively low speeds.
    Put them back for long road trips, when speeds tend to be higher, so aero drag matters more.
  9. Eric "v"
    Eric "v" Member
    229
    44
    'Vegas, NV, Baby
    2013 Prius v wagon
    BTW, I have my 4 original 16" wheels and tires (and wheel covers) for sale on this site.
    Only 3,000 miles on the tires with 95% tread remaining according to Discount Tire.
