Main battery cooling air inlet?
Discussion in 'Gen 2 Prius Technical Discussion' started by TonyR, Oct 26, 2024.
  1. TonyR
    TonyR Junior Member
    Been chasing down a problem with warning lights coming on unpredictably on my Prius that seem to indicate a main battery cooling issue. Have taken the fan out and cleaned it and checked it works. I know the air flows over the fan and then out into the luggage area through two fiilters and out of the vents on the rear seat. But where is the air inlet so I can check that hasn’t got blocked?
  2. Brian1954
    Brian1954 Senior Member
    1,705
    665
    South Central PA, USA
  3. Tombukt2
    Tombukt2 Senior Member
    12,015
    2,124
    Durham NC
    Isn't it on the side of the right rear seat. Should be a rectangular grill sitting right there as you open the door.
    spdracrm3 and Brian1954 like this.
  4. spdracrm3
    spdracrm3 Member
    50
    43
    estacada or
    SM-G960U ?
    Brian1954 likes this.
