Main Battery Error
Discussion in 'Gen 2 Prius Technical Discussion' started by mkitany, Aug 17, 2006.
  1. mkitany
    mkitany New Member
    I just bought a second hand NWH11 model recently and i already have problems.
    The car will not start and it gives the warning Main battery plus the hazard. The prius batteries llok completely drained on the dispaly unit.
    What could be wrong? PLease help!!! :lol:
  2. DaveG
    DaveG Member
    806
    Vancouver, BC
    <div class='quotetop'>QUOTE(mkitany @ Aug 16 2006, 09:48 PM) [snapback]304511[/snapback]</div>
    If it's just the small accessory battery (the 12v battery that starts the car), you can jump-start it from a regular 12v vehicle without any problem (make sure you get the polarity right for the jumper cables).
    If the car hasn't been started in a long time (months), the main high-voltage battery could be discharged beyond what is necessary to start the vehicle. Toyota dealerships have a special charging unit in their shops that they can plug-in to the high-voltage battery to charge it up slowly, to get it running again. It's probably also possible to manually charge the battery without the special Toyota charger, but that would require substantially more technical knowledge as well as knowledge of how to safely work with high-voltages.
    Dave
  3. Tideland Prius
    16,017
    umm... did someone accidentally disconnect the main HV battery? (or did the dealer forget to plug the service plug back in?)
  4. mkitany
    mkitany New Member
    <div class='quotetop'>QUOTE(Tideland Prius @ Aug 17 2006, 12:41 AM) [snapback]304528[/snapback]</div>
    The main HV battery is not disconnected.
    Thanks Dave, however I bought a new 12v battery for it and the MAIN BATTERY warning error still pops up. I tend to believe that the HV battery completely discharged and may therefore need to be charged. The vehicle has not be switched on for more than a month.
    Out of curiosity, how does the manual process of charging the HV batteries work?
    Does it also mean that when the HV battery is fully discharged the engine will not run?
  5. efusco
    efusco Moderator Emeritus
    19,891
    1,191
    Nixa, MO
    Does "second hand" mean salvaged? Did it ever run right then stopped running right? If so, what were the circumstances around that? Finally, this is what the dealers are for. They'll check the CEL and MILs, tell you what's wrong and fix it up.
    BTW, the main battery becomes 'disconnected' electronically in an accident, if this car has been wrecked that 'breaker' (or whatever it is) may need to be thrown even though the battery looks like it's connected.
    Please fill in the blanks here and we might be able to better direct you, but this is kind of like your transmission going out on a regular car, it's not something you put the car in the parking lot for and then ponder what to do, if it's the HV battery or the electronics connected to it you need the dealer to fix it unless you have a vast range of computer, electronic and mechanical knowledge, proper tools and test instruments to fix it yourself.
  6. john1701a
    john1701a Prius Guru
    12,747
    5,243
    57
    Sorry to hear your introduction to Prius ownership hasn't been pleasant.
    There is a possibility that the original owner never had the preventative seal applied to the cells. There was a SSC a few years ago for that. Its purpose was to prevent leaks as the pack ages; otherwise, a failure possibily similar to yours may eventually end up happening.
  7. mkitany
    mkitany New Member
    <div class='quotetop'>QUOTE(efusco @ Aug 17 2006, 07:06 AM) [snapback]304582[/snapback]</div>
    Second hand means the car was sold to me by someone who had used it for a while. It was recently imported from Japan so i wouldn't know its history including if it had an accident. but i trust the Japanese would not sell me a dead car.
    when it arrived from Japan, its 12v battery was very low and had to be replaced. I took it to a garage for a paint job. It took two weeks at the garage. I cannot now move it from the garage.... "shows the main battery sign+Exlamation mark on vehicle at the MFD AND a hazard sign (master warning light) at the Dashboard.
    i hope the 'little' history does the trick
    Mkitany
  8. eagle33199
    eagle33199 Platinum Member
    5,122
    268
    2015 Prius v wagon
    I remember reading somewhere that you are supposed to remove the HV battery prior to certain types of high temperature painting jobs, because it could be damaged by the heat... At any rate, i'd say it sounds like the car was working before you took it to the shop, it should be the shop's responsibility to return it to you in working condition, even if that means having it towed to a dealer to be fixed (remember, only a certified prius mechanic should work on the car)
  9. mkitany
    mkitany New Member
    <div class='quotetop'>QUOTE(john1701a @ Aug 17 2006, 07:21 AM) [snapback]304584[/snapback]</div>
    Sorry John, What is a preventive seal? does it also means that the HV batteries have packed? :eek:
    <div class='quotetop'>QUOTE(eagle33199 @ Aug 17 2006, 08:16 AM) [snapback]304599[/snapback]</div>
    Unfortunately such kind of rules do not work in this part of the world. People get away with murder. I did not think a paint job would have caused much damage to the car...
  10. c4
    c4 Active Member
    607
    51
    I see you're in Kenya, where I'll bet there are not many Prii around; heck you may not even have a Prius tech in the whole country, never mind the special Toyota charger, so you may be completely on your own.. As much as I love the Prius, Africa is the one place in the world where I would probably prefer an old 1980's Tercel with a carburetor and minimal computer electronics that I could repair in the bush without special diagnostic tools and expensive parts which probably are not available locally (your closest bet is probably South Africa)..
    Anyways, if the paint shop left the car on for any significant period in IG-ON mode or in neutral, they could have discharged the hybrid battery beyond the point where it is able to start your vehicle. If the paint shop used a high temperature booth to bake the paint afterwards, this may also have caused battery damage..
    Given your particular situation, your best bet is to try charging the hybrid battery yourself- you'll have to rig up a ~275V DC power supply- some simple transformers and diodes will do, then remove the casing from the battery and using rubber gloves and plenty of care, hook up the charger.. You don't need to give the battery a full charge, just enough that it can start the engine, so just a few minutes on the charger may be sufficient. Once you can start the engine, the on board computers will take over the charging and bring the battery back up to nominal condition- just leave the car running until the engine shuts off on its own, and the battery will be back to a usable charge level..
  11. john1701a
    12,747
    5,243
    57
    <div class='quotetop'>QUOTE(mkitany @ Aug 17 2006, 08:19 AM) [snapback]304600[/snapback]</div>
    It was a special chemical agent that was painted on over the seems to ensure they didn't leak later on.
    For a Classic Prius (your model), it would have been applied after the original owner purchased the car. And unfortunately, based on your location the likelihood of that having happened is less of a guarantee than it is here in the United States.
    Whatever the case, this is one of those situations only a dealer can provide service for. Good luck.
  12. mkitany
    mkitany New Member
    <div class='quotetop'>QUOTE(c4 @ Aug 17 2006, 08:54 AM) [snapback]304616[/snapback]</div>
    Your idea sounds great. However do you have diagrams/images of how to go about it?
    sorry for being such an idiot, but going by my first experience, better sure than sorry.
    you are right about one thing, in Africa, such technology is still beyond us. fortunately, we have a few other daring kenyans like me who have bought the car. Our local dealer currently has one under test for the current market... but no expertise. The roads here are also jungle roads.
  13. c4
    c4 Active Member
    607
    51
    "Special chemical agent"???? There was no "special chemical agent" unless you count the boric acid solution that they provided to neutralize any of the potassium hydroxide electrolyte that may have leaked out.. There were MSDS in the back of the SSC 40G instruction sheets that said that the sealant was a simple 3M water-based acrylic sealant that was gooped onto each of the negative terminals; the other part of the package was an absorber pad that was glued on top of the positive terminals with the same 3M sealant to soak up any subsequent leakages..
    As for the charging process, you're on your own; there's just too much liability involved in providing any sort of detailed instructions for a process where you could potentially kill yourself or irreparably damage the battery or the car, so it's one of those things that people will give you hints for, but you basically have to do it yourself.. There are many documents on the internet describing how to take apart the battery (including the aforementioned SSC 40G instruction sheets, which may be available here on PC in the knowledge base, and if not, then certainly on the Yahoo group maintained by Michelle Vadeboncoeur where she archives all of the Toyota recall/special service campaign/technical service bulletins.. Similarly, you should be able to find many schematics of high voltage DC power supplies on the internet..
  14. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    In the US the Main Battery Charger is kept by the Regional service reps so there are like a half a dozen in the whole US. I hope you really do not need a charge and it is a circuit breaker problem.
  15. David Beale
    David Beale Senior Member
    5,963
    1,979
    Edmonton Alberta
    It's a low capacity (a few A/Hr) nickle metal hydride battery. 208 V nominal. You'll need about 250V DC at about 200 mA to charge it. Make sure you limit the current! Charge at this rate for an hour or so and it should have enough energy to start the ICE, which will then take over. Be sure to fully disconnect the traction battery before charging it, as the charger could damage the electronics.
    Read the above mentioned document. It outlines how to safely disconnect and connect the battery. DC is much more dangerous than AC. AC can kill you at these voltage levels, but you can let go if you touch it and you will usually survive. What makes DC so dangerous, is you can't let go. It causes your muscles to contract and you freeze to the power. It will kill you more often than equivalent AC.
    Please be careful!
  16. tochatihu
    tochatihu Senior Member
    8,973
    3,501
    Kunming Yunnan China
    2001 Prius
    Re: David Beale's, the original poster has an NHW11 model so the hybrid battery is 274 volts nominal. Based on what I've read in the Yahoo Prius_Technical_Stuff group, one approach would be to separately charge the two half-strings with 150 vdc. Again, using extreme caution...
  17. mkitany
    mkitany New Member
    <div class='quotetop'>QUOTE(tochatihu @ Aug 18 2006, 02:54 PM) [snapback]305522[/snapback]</div>
    You reckon i use 274V power in? I will go to the yahoo Prius_Technical_Stuff group and see how to separate charge because our AC power is regulated at between 220-260 V, with the standard being 240V.
  18. mkitany
    mkitany New Member
    <div class='quotetop'>QUOTE(mkitany @ Aug 19 2006, 01:19 AM) [snapback]305780[/snapback]</div>
    I notice that you can jumpstart and charge a HV battery vehicle in Prius NWH10 and NWH20 using a 12v battery. Is there a way of also jumpstarting and charging the NHW11 model using a 12v battery?
  19. mkitany
    mkitany New Member
    <div class='quotetop'>QUOTE(mkitany @ Aug 19 2006, 04:22 AM) [snapback]305798[/snapback]</div>
    Is there a place I can download the NWH11 model owners manual.
  20. brandon
    brandon Member
    771
    Manhattan, KS
