Main Hybrid Battery
Discussion in 'Gen 2 Prius Technical Discussion' started by pakhong111, Jun 15, 2014.
  1. pakhong111
    pakhong111 Junior Member
    31
    My 2004 Prius (original owner) has 250,000 miles on the odometer and I'm just wandering due to the age and miles on the car, how one can tell in advance when the battery will need to be changed since it is very costly.
    Secondly, my dealer informed me from a recent oil changed that my auxiliary has a low charge and it should be replaced. I last changed the 12v battery in 2009 (5 years ago) at 99,000 miles on the odometer by the dealer and was curious whether the replacement is as simple as replacing batteries in a non-hybrid vehicle, since I would like to replace it myself.
    Anyone with such information would be deeply appreciated.
    Thank you.
  2. Easy Rider
    Easy Rider Active Member
    982
    210
    N. Central Florida
    Except for being rather cramped and hard to get to, the procedure for replacement is no different than any car.
  3. jdenenberg
    jdenenberg EE Professor
    3,852
    1,845
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Your Dealer or anyone with a Prius-aware OBD2 tool can read out the status of your HV battery modules. Look for variation in module pair voltages or module pair resistances as they indicate if the HV battery modules are getting unbalanced. One location in Florida where they can do this (other than a dealer) is:
    Mellor’s Automotive Inc.
    1410 W. Newhaven Ave.
    West Melborne, FL 32904
    (321) 956-1997
    Contact: Joshua J. Mellor
    [email protected]
    JeffD
  4. wjtracy
    wjtracy Senior Member
    11,324
    3,591
    Northern VA (NoVA)
    Jeff is the SCANGUAGEII Prius aware?
  5. jdenenberg
    3,852
    1,845
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Yes, as are several other options.
    JeffD
    wjtracy likes this.
