Maint Req'd Light
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Tideland Prius, Mar 24, 2005.
  1. Tideland Prius
    16,123
    Hey,
    I read in the manual that the light will come on for 3 secs, then flash for 12 secs when the odo reads 7,200kms (4,500mi) then stay on after 8,000km (5,000mi) in IG-ON mode.
    So far, I haven't seen the light I'm already at 7,600kms. Is this a US only feature?
  2. Devil's Advocate
    922
    Las Vegas, Nevada
    Where did you read that?
    It is true. I just hit 4,500 and it blinks then goes out.
    The Prius is going in next week for it 5k check-up anyway, I think that is what the light is for.
  3. Tideland Prius
    16,123
    Well, this is what I mean. Your light came on, mine hasn't lol
  4. jayman
    jayman Senior Member
    13,439
    640
    Winnipeg Manitoba
    Sorry, the Canadian market Prius doesn't have that feature.
  5. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,339
    917
    251
    Surprise, AZ (Phoenix)
    The MAINT REQ light is a US only feature - the NCF confirms this.
    Mine's on, but I'm running synth so I don't fear letting it slide till I find a good price for 4 qts of full synth.
  6. Tideland Prius
    16,123
  7. hnational
    hnational Junior Member
    24
    uptown, chicago
    Hey folks,
    i just got my oil changed last night at 4800 miles. I thought the dealership would have reset it for me. I called and talked to the prius tech guy there today and he told me that I could bring it in. He also told me how to get rid of the blink on my own. I haven't tried it but it seems simple enough.
    power down,
    hold down the ODO button
    at the same time hit power without touching the brakes
    there should be a counter on the display that shows a series of dashes.
    hold the ODO button down until all of the dashes go away and it shows zeros all the way across.
    then, power down and start up completely to make sure it's gone.
    the guy told me to make sure i keep the ODO button held down the whole time though.
    has anyone else tried this?
    If this doesn't work when i try it in the next couple of hours then i will post a correction - stay tuned.
  8. DanMan32
    DanMan32 Senior Member
    3,799
    26
    Tampa Bay, FL
    It is documented in your owner's manual.
  9. rwithop
    rwithop New Member
    121
    SF Bay Area, CA
    As if, we're supposed to read the "Owner's Manual." What do they thiink we are idiots!
    OK. I'll admit. I just had this same experience today and had the dealership show me the method mentioned above to reset it. Hey I thought these suckers could go on a 7,500 mi cycle like the Highlander.
    Ryan
  10. hnational
    24
    uptown, chicago
    update from yesterday's post:
    it works but i had to hit power twice to get the dashes to show up.
    if anyone else tries it make sure you hold the ODO button down and hit power until you get the amber dashes on the heads up display.
    rawk on
  11. Brent
    Brent New Member
    69
    33
    Question:
    I have a new 2005 Prius. In the Nav System Owner's Manual it describes how to program maintenance items using the MFD. Do we really have to manually program this data, or does the Prius automatically show required maintenance at pre-set intervals? It seems ridiculous that Toyota would have left this to the owner to program.
    Thanks,
    Brent
  12. DanMan32
    3,799
    26
    Tampa Bay, FL
    You have to program it. Actually, you could use the slots for anything you want. Much of the stuff doesn't apply to the Prius anyway.
