Maintainance Required visit dealer
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by ETP, Jan 12, 2019.
  1. ETP
    ETP 2021 Prime(Limit),Highlander HYB Plat,B52-D,G,F,H
    2,799
    1,170
    Auburdale FL
    So I assume this is the oil change stuff. How do you get rid of it. Thought I knew how but I guess I forgot.
    Seems it was in setting somewhere on one of the pull downs but the MX icon has no pull downs.
  2. ETP
    2,799
    1,170
    Auburdale FL
    Found it! Select settings in the instrument information center then go down to vehicle settings and do the reset.
    It is not under the MX triangle group.:mad:
    Mendel Leisk and krmcg like this.
  3. Mendel Leisk
    38,207
    Us Canadian owners miss out on all the fun, don't have that "feature".
  4. FuelMiser
    FuelMiser Senior Member
    1,268
    860
    Monument, CO
    The mx reminder comes on 5,000 miles since last reset, but oil change interval is 10,000 miles on 0W-20 oil. At the 5,000 mile intervals between oil changes, you should still check the fluid levels and tire pressures at a minimum.
  5. Mendel Leisk
    38,207
    Tire rotation is every 5K.
    Tyfly likes this.
  6. alanclarkeau
    alanclarkeau Senior Member
    7,041
    7,580
    near Brisbane, Australia
    Quite sure it's not here either.
