Maintaining settings during 12 volt battery change
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by lenjack, Feb 13, 2014.
  1. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    I know there are battery "thingies" that plug into the lighter, which supposedly preserve the settings, but since the lighter is not "hot" whrn the car is not running, I don't see this working. How to do?
  2. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    TsKarma likes this.
  3. Mendel Leisk
    38,707
    Hook a low amp trickle charger to the the battery cables. Or pos to cable and neg to exposed metal. Be VERY careful to get it right way 'round. Then disconnect the battery, you should be fine, memories retained.
    DadofHedgehog and TsKarma like this.
  4. Mendel Leisk
    38,707
    You could do it at the jumper point, under-hood, too: would work the same.
    TsKarma likes this.
