Maintenance at 150k miles
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by tom1l21, May 14, 2012.
  1. tom1l21
    tom1l21 Member
    268
    East Longmeadow, MA
    Hello,
    I just reached the 150k mi mark, I was wondering what type of maintenance I might need to do or if there is anything worth checking up on.
    I bought my '05 in 2009 with 82k miles on it and since then, I've only performed the standard maintenance of new tires, oil changes, air filters, and a 12v battery. Any suggestions? Thanks!
  2. maestro8
    maestro8 Nouveau Member
    471
    109
    nor cal
    Did you not read the maintenance schedule included with the Owner's manual?
    Did you not try calling the dealership to find what they recommend?
    From what I heard from my dealer's service advisor, he said most fluids in the car were rated to 100k miles.
    Sounds like you're about 50k miles overdue. Why'd you wait so long?
    I'd start by changing engine / inverter coolant and transaxle fluid. And while it's not listed in the manual, I'd do the brake fluid too, if you're fond of stopping.
    If you really want to go the whole nine yards, check plugs and belts, suspension bushings, CV boots... after 150k miles, anything that's rubber should be carefully eyeballed.
  3. tom1l21
    tom1l21 Member
    268
    East Longmeadow, MA
    Thanks for the reply. I never received an owners manual with my car so I was unaware of those. Would changing fluids over be something I could do or should I just take it into a shop? I'm just worried about getting hosed on prices.
  4. jdenenberg
    jdenenberg EE Professor
    3,953
    1,949
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Fede:) and tom1l21 like this.
  5. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Here's the deal, Maestro, While the owners/maintenance manual is a good starting place for what to get, if you take a peek about with those who really know what they're talking about, you can find out that there are things that really should be done, that are not in the books, and things that really don't need to be done, but are/were included in the book. This is particularly true for the 2nd gen Prius which is very much a cut and paste of the traditional ICE manuals in several areas and do not take into account the unique operational characteristics of the HSD. Further, if you like getting raped without KY you'll go to the dealership service department and ask what you need. You'll be upsold hundreds of dollars worth of completely unnecessary crap. You'll be offered the cabin air filter upgrade for $80--a part you can buy on ebay for $6 and change yourself in about 30 seconds. They'll flush stuff that doesn't need flushing and recharge stuff that doesn't need recharging.
    Thus, this is an excellent question and it's asked in the right forum. Snide RTFM type answers are not necessary or appropriate.
    So, to the OP. I haven't hit 150k yet, so haven't personally studied up on exactly what you need, but here's a great place to start your research.
    http://priuschat.com/forums/gen-ii-...70-what-services-you-need-what-you-don-t.html
    kenoarto, Gaetano, Fede:) and 9 others like this.
  6. maestro8
    471
    109
    nor cal
    What's your comfort level? You do your own oil changes? The transaxle fluid change is fairly straightforward in comparison.
    A coolant change involves some monkeying with electrics to get the system properly bled... there are threads on this topic here, do your research, see if it is worth the time and hassle to save a few $$$.
    The brakes, also not straightforward. Read up here: Brake service You may want to pay for this, if you want it done.
    Think of it this way. Pay a little for maintenance now, or a lot for repair after your car becomes undriveable.
    Shop around. A few phone calls can save you a few $100s. Do your research, decide what you want done up front, and draw the line there. Don't let the shop feed you a string of "while we're in here...", get them to document their recommendations (they'll be much less eager to put their BS on paper), and decide once the car's back in your hands.
    ...and you drop in to tell me "the deal"? Why should I take you seriously if you don't even bother to do your homework before chiming in?
  7. tom1l21
    tom1l21 Member
    268
    East Longmeadow, MA
    Hey thanks for the reply, I like to think of myself as somewhat technically capable (I installed the EV button, replaced my 12v, do own oil changes, etc) so I was looking to be able to perform any of this myself. I haven't noticed any issues over the course of ownership as well so I'm feeling pretty good about my Prius. And yes I avoid dealerships like the plague...
    Short story: when I bought my Prius from a small car salesman, the FOB wasn't working so he told me to take the car and FOB to a Toyota dealership to have it fixed. The dealership said they ran a scan on my car and that the entire Key less Entry CPU needed to be replaced for $1900. I told the salesman I bought it from and he took care of it himself (the FOB was simply dead).
    I took a look at that link and all those sound like something I wouldn't be able to do myself (read:expensive). What's it cost (about) to have trans-axle fluid, inverter fluid, etc replaced?
    PG86100 ? 2
  8. jdenenberg
    3,953
    1,949
    Trumbull, CT
    2020 Prius
    LE AWD-e
    A drain and refill of the transaxel (about 4 qts of Toyota type WS ATF) is $100 at my dealer in CT but YMMV so take care. I suggest, based on lab testing of ATF every 60k miles in my 2004 Prius, that the appropriate schedule is a first drain/refill at 30k miles and then every 60k miles thereafter.
    You need to determine if the FREE replacement of the inverter electric coolant pump (A recall due to design flaws. It should include a refill of that coolant) was done. If so that sets the schedule going forward. You may want to consider a preventative replacement of the mechanical engine water pump and serpentine belt when that coolant loop is due.
    JeffD
  9. efusco
    19,891
    1,196
    Nixa, MO
    Because 1)I've been doing this for a long time and know what I'm talking about. 2)B/c I referred him to a source where he could find the answers that will actually be helpful to him.
    I would have preferred to give him a polite detailed answer, but unfortunately was short of time and didn't want us to lose a forum member b/c of a snide reply by someone telling him to RTFM.
    Further, I wanted to turn him away from what you'd told him to do--RTFM b/c it is not an ideal source--though I acknowledge a decent starting point.
  10. maestro8
    471
    109
    nor cal
    So you came to bark at me for pointing the OP towards a decent starting point?
    Thanks for the FUD, but it does the OP no good.
  11. Codyroo
    Codyroo Senior Member
    1,826
    515
    Pleasanton, Ca
    Maestro8,
    If your first reply eliminated the first 4 paragraphs/sentences, you would have come across as being quite helpful. (i.e. this)
    Your first 4 lines sound like you are scolding the OP and that is what Evan is saying is unnecessary. And Evan is correct.
    Gaetano, Fede:), DLC82SV and 5 others like this.
  12. maestro8
    471
    109
    nor cal
    In the first four lines I suggest the OP should start with talking to the dealer and looking in the manual... because as far as he knows, we're just another bunch of idiots on the Internet (and he'd be right).
    Now if it happens to be the case that we echo some things the dealer says, then that would help the OP understand what he needs to do.
    But without those first four lines, he'd be blindly following the advice of some Internet idiots. And you'd like me to hold his hand and tell him that it's okay?
    Sometimes, people need a little slap of reality. It might sting, but in the long run it does more good than harm. I'm not saying I'm the person that should be doing the slapping... but wouldn't you think it's better that it's done now than after he faces a big repair bill from following bad Internet advice?
  13. tom1l21
    tom1l21 Member
    268
    East Longmeadow, MA
    I guess I was being lazy by not doing the first 4 steps you suggested, but over the last 10 years or so, I've been helped immensely by the communities via a forum. I skipped the steps that you've outlined in the beginning since grabbing first hand experience from others has usually proved more useful to myself. Sometimes I'll spend countless hours researching for a sub $50 product, so I wouldn't consider myself incapable of searching out the info I needed, but I do understand where you are coming from and do appreciate the help.
    PG86100 ? 2
  14. rposton
    rposton Member
    139
    Nashville, TN
    I have an '06 and I have never had my transaxel fluid replaced that I know of.
    Every 5k I have an oil change, oil filter, tire rotation done. I put in one of those million mile K&N air filters, so it gets taken out, cleaned, and reoiled every now and then. I do my own cabin filter. I also add in a bottle of injector cleaner to the tank. Mostly DIY stuff.
    Every 100k I go to the dealer and have them, do all the above, + coolant in both cooling systems, + drain and refill the brake fluid, + replace the PVC valve, + plugs and wires on the ICE, + spray carberator cleaner into the throttle body. It has cost me approx. $600 each time all this is done.
    Currently have 322k + miles on the car. Same batteries, same brakes, same about everything else with the exception of the HID bulbs, and the tailight bulbs, and I have lost the windshield 3 times due to flying rocks on the interstate. Well actually serverly crack it and then get it replaced. Costs me $200 each time. New tires about every 16 months.
    Last 100k service event, dealer told me that I needed the inverter pump replaced, something about a recall on them, I said ok.
    About the throttle body/carb cleaner/gas additive thing; at about 30k miles, sitting in a hot parking lot on a hot day with the AC running, doing paperwork, the red triangle came on. I drove the vehicle to the dealer, pointed at it and said fix it. Dealer said there was some gizmo device that would cost $1500 to replace. I sucked in my breath. Dealer then said that it could just be a dirty sensor in the throttle body. Dealer offered to clean it with carb cleaner, see if the red-triangle goes away. He did, and it did, and I started adding injector cleaner at every oil change, and asked the dealer to reclean the throttle body at the 100k checkups, and it has never come back.
    Referring to the 2nd posts. I bought my Prius new. During the 1st 100k miles, I took the car to the dealer for the 5k service. Dealer had a service writer which was interested in looking at my Owners manual with me to decide on what service needed to be done. He was also sympathetic to what I had read on Priuschat.com. About 1.5 years later, that service writer left and I found that the other service writers did not car what my owners manual or Priuschat.com said. Instead they would printout their "recomendations" and it looked like it would more fit an Avalone. I remember asking them about the "automatic transmission service" that they wanted to sell me. I decided that they were more interested in seperating me from my money, than servicing my car. However, when I am very clear on what exactly I want done, the work has always been done right. So I still prefer the dealer for the 100k service intervals.
  15. NuShrike
    NuShrike Active Member
    1,378
    Replies have been very little help. For Google posterity, RTFM rants are pollution. Also doesn't help the linked manual doesn't even detail 150K.
    From efusco and galaxee I can only glean: oil change, clean/adjust rear brakes, drain/refill engine/inverter fluid, and possibly PCV valve replacement. More than what I can ask a local mechanic to do. Nearest Presidential Cabinet award Toyota is ~1 hr away, so some pita to get these services done.
    I fill only with Chevron so I'm not worrying about injectors.
    Had the water coolant pump replaced twice: when it failed in ~2009 and I paid out-of-pocket, and again when the recall was reinstated and Longo wanted to be sure it was done.
    Gaetano and evilchargerfan like this.
  16. tom1l21
    tom1l21 Member
    268
    East Longmeadow, MA
    Damn that's a lot of miles, I just redid my stock sparks after 160k. No more engine knock :). I was thinking about cleaning the PCV valve but I heard its a pain to get at typically with little no no improvements in FE etc.
  17. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
  18. Mendel Leisk
    41,874
    ^ Yes, get the transaxle fluid changed. Be interesting to see what it looks like. :eek:
  19. Patrick Wong
    18,210
    6,512
    It is true that a clogged PCV valve does not impair fuel economy. That is not the point.
    The point is to have a properly operating emissions control system and to purge hydrocarbon buildup from cylinder blowby that gets into other parts of the engine, which may cause sludging over time. A seriously clogged PCV valve may also lead to engine gasket leakage over time, as pressure in the engine builds up which is not relieved by crankcase ventilation via the PCV valve.
    It is also true that it is not particularly easy to access the PCV valve as the engine wiring harness over the cylinder head has to be removed for access. However, this is an important maintenance activity at 100K miles and should not be overlooked.
  20. Patrick Wong
    18,210
    6,512
    If you had not previously applied for a refund for the 2009 repair and you still have the repair invoice available, you might write to the Toyota Customer Experience Center, cite the applicable LSC, provide a copy of the invoice, and you should receive a refund in a few weeks.
    DLC82SV and NuShrike like this.
