Maintenance at 168,000 miles
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by mikeg1, Mar 14, 2011.
  1. mikeg1
    mikeg1 New Member
    Auburndale MA
    The only maintenance I've had on my 2005 Prius, 168,000 miles, has been tires, oil changes and water pump (besides recent "antifreeze" recall). Should I be concerned about any impending failures, based on other's experiences? 12V battery seems OK, and don't want to spend big bucks to replace. Ditto for brakes. Mileage dropped off this winter to high 30's, but has since recovered to mid-40's.
  2. jdenenberg
    jdenenberg EE Professor
    3,859
    1,858
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Change the Transmission Fluid (Toyota Type WS). Your Dealer should charge about $100.
    The only failure I've had was the upper steering column assembly $900 at 150k miles
    JeffD
    ps: My 2004 Prius is at 193,500 Miles
  3. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    So, you're still on the original 12 volt? How are your determining that it seems "ok"? If still on your original, it's likely on its last legs and reading very low voltages.
    I would REALLY change the PSD fluid at this point. FWIW, some dealers claim that the fluid is "lifetime fluid" and the dealer I called today claimed it didn't need to be changed until 120K miles. Most repair experts on PC here disagree.
    I'm not waiting that long and am going to do it before the 51K mile mark.
  4. Mendel Leisk
    38,876
    Have you ever had a thorough brake inspection? :eek:
  5. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    510
    63
  6. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,999
    Fort Lee, NJ
    Spark plug is overdue. The schedule is at 120k miles.
  7. ksstathead
    ksstathead Active Member
    1,244
    244
    Kansas
    1. Transaxle oil
    2. Spark plugs
    3. Serpentine belt
    Save up for a 12V, 'cause it has to be close to its end.
  8. SageBrush
    SageBrush Senior Member
    11,627
    2,531
    Southwest Colorado
    Hobbit wrote up a fascinating monograph on brake fluid maintenance. His two basic observations were 1, brake fluid ages most slower in a Prius than a regular ICE car because the friction brakes are little used; and 2, a simple copper strip test is probably enough to check brake fluid quality in deciding if a flush is needed. I am convinced, and do not plan to flush the fluid based on a mileage number.
  9. mikeg1
    mikeg1 New Member
    Auburndale MA
    Thanks for your feedback. The dealer has commented during past oil changes that the brakes might need repair/replacing only based on the rusted condition noted. I'm not really hearing any noise, adn most of my mileage has been on highways.
  10. Hal W
    Hal W New Member
    872
    53
    Grand Forks,B.C. Canada
    Boy, that car has been really good to you! Hope mine does as well? Hal
  11. Mendel Leisk
    38,876
    Toyota seems very vague on the subject of brake inspection, at least comparing to Honda, which is my past ownership experience. Honda's maintenance schedule call for brake inspection yearly, typically. And, the Shop Manual has a thorough and clear explanation of what the entails, basically pulling off the pads, cleaning, relubing and re-installing. Also, check of disc run out, parellelism, thickness, though this tends to be good for a long time, at least till the discs wear thin.
    Drum brake shoes need inspection too, lube of the contact points with the housing, and check of thickness obviously.
    I'm a little perplexed that a dealership lets you go that distance with no decent inspection. And quite candidly, would not want to have to do a panic stop in front of you.
    Addendum: The Toyota Repair Manual may be part of the problem:
    The brake sections basically explain a complete tear-down of the brakes. There is no explanation as to what a brake "inspection" entails. Obviously it's not complete disassembly, but what is it? It seems to be simply a check of pad thickness, maybe without even swinging up the caliper for a clear view, from what I've heard about dealerships.
  12. Mendel Leisk
    38,876
    [deleted, duplicate post]
  13. mikeg1
    mikeg1 New Member
    Auburndale MA
    Again, it's been primarily highway miles, since my commute after buying the Prius was ~100 miles/day for the first 3 years, then 1/2 that amount since then. Except for a troublesome CD insertion problem, I definitely have been lucky, though will take the advise given above to check and change as needed, battery, fluids, plugs, etc.
  14. mikeg1
    mikeg1 New Member
    Auburndale MA
    Thanks. The dealer that I've been using, up until last year, always seemed to find something, just to make money(?). They recomended new brakes, again, based on rust alone, but I've since switched dealers, and will get an inspection shortly. The brakes, however, seem just fine, w.r.t. stopping distance.
  15. jdenenberg
    3,859
    1,858
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Mike,
    CD problems are common in Early Gen2 Prii. I bought a replacement stereo that was salvaged from a 2006 from:
    Plug In Hybrid Electric Vehicle PHEV (Steve is a great guy)
    for $82 (including shipping from Indianapolis). There are full instructions at that site for removing the MFD and then the Stereo which takes about 30 minutes (as does installation). If you feel insecure about DIY, just bring the instructions and the replacement stereo to any decent car stereo shop.
    JeffD
