maintenance costs for Prius ll
Discussion in 'Gen 2 Prius Main Forum' started by mark54321, Mar 1, 2011.
  1. mark54321
    mark54321 Junior Member
    39
    Nutley, NJ
    Hello:
    I'd like to know the approximate cost people have paid for maintenance on their Prius. I'm thinking of purchasing a Prius II and I'm likely to put about 700 mi. per week on it...
    I have a 2000 Acura Integra now w/ 300,000 mi...I'll prob. need to get that from the Prius.
    Anybody have one w/ 100,000 + mi? I was wondering about the costs of replacing tires/ timing belt/ brakes etc...
    The other car I'm considering is the Golf TDI diesel. Trying to get a feel for both.
    Thanks
    MC
  2. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    You can take a look at Advanced Vehicle Testing Activity - Hybrid Electric Vehicles. There is no timing belt. The Prius uses a timing chain. You can get an idea of tire costs via Tire Rack - Your performance experts for tires and wheels
    This post is in the wrong area, but if you're considering a 3rd gen, there are also no belts. The water pump, power steering and AC are all electrically driven.
    Many folks have gone over 100K miles on the original brake pads since regenerative braking does so much of the work. http://www.ctvbc.ctv.ca/servlet/an/...ility_110125/20110125?hub=BritishColumbiaHome should give you an idea how much longer the brakes last.
  3. derkraut
    derkraut Member
    299
    27
    SAN
    I have a 2006, with 44,000+mi on the ODO. I do all my routine maintenance myself. My TOTAL maintenance costs so far (4 1/2yrs) is $197.79, which includes: 8 DIY oil & filter changes, 1-engine air filter, 1-cabin air filter. (got the filters on EBAY for 50% less than dealer prices) The inverter coolant pump was replaced at no charge under recall. I will be replacing the tires at around 50K miles, with Michelin Energy Savers. Absolutely no issues whatever so far. The car has never been in a shop/dealer, except for the recall mentioned above. Lifetime MPG =49.3. I live in San Diego, which has ideal driving conditions for optimum fuel consumption, of course. But, I live in a "hilly" area, which uses a bit more fuel, on average.
    BEST car I've ever owned; and I've been driving for 60+ years.
  4. vnhk
    vnhk New Member
    106
    san jose
    You will save more money with Prius as you drive a lot. Over long term, it will cost a lot less to maintain than normal car.
    On a side note, what maintenance did you do to get the Acura to 300k miles? I'm curious becuase I also have 1998 Integra LS at 165k right now.
  5. jdenenberg
    jdenenberg EE Professor
    3,857
    1,857
    Trumbull, CT
    2020 Prius
    LE AWD-e
    My 2004 Prius is at 193k miles. Oil (&filter) changes every 5k. AIr & Cabin filter every 30k miles. ATF drain/refill every 60k miles (~$100). Tires every 45k miles. Plugs, PCV, coolants after 100k miles (coolants every 50k thereafter). Still on the original brakes and batteries. New water pumps (2) every 150k miles. The only repair was a steering column problem at 150k (~$900).
    I have saved $12k in gasoline costs to date!!! (compared to if I drove our Jetta 193k miles)
    JeffD
  6. mark54321
    39
    Nutley, NJ
    Thank you for your note. I had an 89 Integra and traded it in at 330,000mi. Then got a 1999 that was stolen almost immediately....then got a 2000 and got 287,000 before one of my cyllinders lost compression.,..and so I had another engine put in that had 90,000mi and also had a new clutch (I was on original) and timing belt (replaced every 95,000mi). Of course tires every 50k and tune ups about every 45k..plugs were replaced once. The car never failed to start. I'd keep the car longer but I will be driving even more in the near future and just need the extra gas mileage...I'll try to sell my Integra which almost looks like new except for bumper scratches. Those were great cars, and it seems the Prius is even better. I hope to get the same reliability. Thank you for your time and info.
    Mark C.
  7. bisco
    49,652
    if you don't mind my asking, what do you do that you put so much mileage on your car and do not get reimbursed? i'm wondering because we reimburse our salespeople .50/mile and they put 30-40,000 a year on their vehicles.
