Maintenance for front power seat?
Discussion in 'Gen 3 Prius Main Forum' started by Johnny Cakes, Apr 20, 2025.
  1. Johnny Cakes
    Johnny Cakes Senior Member
    1,035
    773
    Virginia, USA
    For reasons not relevant to this question, I have to my power driver's seat all the way forward and all the way back several times per day. Every day.
    I'm thinking that the power seat was not designed for this duty cycle.
    Is there anything I should do as maintenance and to prevent failure? Lube? Grease?
    My fear is that the seat moving breaks in the fully forward position, making it impossible to drive.
  2. BiomedO1
    BiomedO1 Senior Member
    2,725
    1,455
    SacTown, Ca
    IMHO; you should probably rip it out for inspection, cleaning and relube, when you have time. Lots of things get kicked under the seats over the years. Hair balls, dust, and dirt would probably accumulate on any exposed lubed surfaces, so it'll need to be cleaned and relubed to prevent failure.
    Good Luck......
  3. JC91006
    16,652
    8,503
    Maybe you should think about getting a manual operated seat? as a spare, in case your power seat motor breaks from overuse
