Maintenance message Hybrid cooling part
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by dyun1dyun1, Jun 24, 2020.
  1. dyun1dyun1
    dyun1dyun1 Member
    53
    35
    Severn, MD and Boone NC
    2017 Prius v wagon
    So I received the a maintenance message to take my car to the dealer for hybrid cooling part. Adjustments.jpg
    I found a you tube video to clean the battery vent. Wife had a 6 hour round trip drive and I had to head to work. So I went ahead and tried to clean the intake filter screen. The message which did pop up twice the last two days during short 10 min drives did not return.
    I’ll make some time to clean the actual fan when I have more time. Just wanted to share what happened.
    2017 Prius V Five
  2. Mendel Leisk
    38,653
    I got this cartoon book "strange planet", for Father's Day, and gotta say: that message sounds straight out of the book. I would definitely clean the fan. It may be not bad, or seriously clogged. Either way it's good to know.
    Google search:
    strange planet comic
    dyun1dyun1 likes this.
  3. dyun1dyun1
    dyun1dyun1 Member
    53
    35
    2017 Prius v wagon
    Cool comic strip!
    2017 Prius V Five
    49,397
    i believe they want to change your filter due to reduced airflow
  5. dyun1dyun1
    dyun1dyun1 Member
    53
    35
    2017 Prius v wagon
    Make sense due to reduced airflow. And btw, there was no filter, just a screen so air can flow to the fan.
    2017 Prius V Five
  6. bisco
    49,397
    i wonder if they program that message every so often to get you to a dealer
  7. dyun1dyun1
    dyun1dyun1 Member
    53
    35
    2017 Prius v wagon
    Totally.
    2017 Prius V Five
  8. Mendel Leisk
    38,653
    I've never seen it.
  9. bisco
    49,397
    me neither, seems to be on the v a lot iirc
  10. Jaime in LB CA
    Jaime in LB CA New Member
    Los Angeles County, California
    2017 Prius v wagon
    I got the same notice on my 2017 Prius V; called Cabe Toyota in Long Beach, California where I live; the service tech said there might be something blocking the vent under the rear, passenger seat. I took a look under the seat and the grate / filter assembly in front of the vent was caked white with what I can only guess was ash particulate; as, I had just completed a 3-day roadtrip to Sonora, California; that's right in the middle of the current, California fires. I thought about cleaning it myself until I also looked at some YouTube videos & realized the rear seat had to come out; so, I took it to Cabe Toyota today. They charged me $200 to service the hybrid battery vent; drove away & went to a next-door drive-in car wash; afterwards, I popped my head inder the seat again to look at the vent. The filter was gone; only the grate was there; I could see straight into the vent's housing. I called the service tech I'd dealt with to tell him there was no filter on the grate. He spoke to the service tech and that man told him the 2017's did not come with a filter on the grate in front of the vent's housing; but, I'm positive I saw a filter on the grate caked with what was white, ash particulate, as I mentioned. I've joined this forum exactly for this experience; as, I'm hoping someone can tell me if the 2017 Prius V's do come with a filter over the grill that leads to the vent for vent that cools the hybrid battery. Anyone care to comment?
  11. icyrius
    icyrius Active Member
    232
    111
    Florida, USA
    2014 Prius v wagon
    Here is a picture of mine. Does yours look like this? 453342C9-2AF6-4665-ACB1-CBDD34E44C78.jpeg
  12. dyun1dyun1
    dyun1dyun1 Member
    53
    35
    2017 Prius v wagon
    It’s a little hard to see But that looks about right but I am not 100% until I need to clean it again.
    2017 Prius V Five
    #12 dyun1dyun1, Sep 23, 2020
  13. VFL16
    VFL16 New Member
    Knoxville, TN
    I was inspecting my fan filter and duct assembly on my 2012 v (no issues, just wanted to make sure it was clean).
    I noticed my filter grate does not have the dust screen either, just like someone above mentioned. It is only the plastic grate. It looks exactly like the picture posted, but there's no actual filter screen.
    I'm no expert, but this seems fundamentally problematic as it would openly allow more dust and debris into the fan. However, I've never received any error messages, the grate itself actually looks pretty new and mostly clean, the duct has some dust but not as much as you'd think, and the fan isn't dusty inside. Am I missing something? My backseat is almost always empty, nobody ever rides back there, and I keep the car clean, so maybe that's why.
    I'm debating replacing the part altogether so I can have a filter, since that just seems like better practice. On the other hand, if it isn't broke don't fix it. Since someone else has noted they have no screen, maybe there is a reason this piece is the way it is?
