Maintenance mode
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by JDenyer232, Oct 13, 2016.
  1. JDenyer232
    JDenyer232 Member
    44
    46
    Maine
    Just thought I would let you all know that you can get into the maintenance mode on the gen 4 the same way as the gen 3 using the gas pedal shifter and brake sequence. Just tried it on mine after an oil change and started up the engine so I could check for leaks. Works like a charm.
    RCO likes this.
  2. nategold
    nategold Member
    117
    38
    Arlington, MA
    What does that do and what is the sequence?
  3. JDenyer232
    JDenyer232 Member
    44
    46
    Maine
    Maintenance mode will run the engine at idle whether it needs it or not. It's useful after working under the hood and checking for leaks after oil and coolant changes. I will post the sequence tomorrow as I don't have it in front of me right now. Just don't drive it in maintenance mode as it disengages the traction control and that could damage the transaxle. To turn maintenance mode off just turn the car off and when you turn it on again the car will function as normal.
    RCO likes this.
  4. kithmo
    kithmo Couch Potato
    2,404
    2,773
    47
    South Yorkshire, UK
    I've never heard of the "gas pedal shifter and brake sequence", I used to use the info button and headlights on/off 3 times on the Gen 3 and Prius+, but it doesn't work on the Gen 4.
    RCO likes this.
  5. JDenyer232
    JDenyer232 Member
    44
    46
    Maine
    Here's the procedure.
    press 2 times start buttuon
    press 2 times gas padel
    hold brake padel put P to N
    hold brake padel put N to P
    press 2 times gas padel again
    put foot brake padel and start engine............
    engine become inspecion mode/maintainencemode........
    Hope this helps.
    CT415, jolynf13, kithmo and 3 others like this.
  6. priusgto
    priusgto Active Member
    193
    227
    Northern Arizona
    I just step on the gas one time and it will start up. Runs long enough to check for leaks.
    RCO likes this.
  7. FuelMiser
    FuelMiser Senior Member
    1,300
    888
    Monument, CO
    I've never had a problem with the ICE starting up on its own after putting the car in normal READY mode following an oil change to check for leaks, etc. After a few seconds, it just always starts up. I would think an easier procedure than "maintenance mode" would be to ask for cabin heat if the ICE doesn't start on its own after a few seconds.
    RCO likes this.
  8. Mendel Leisk
    38,735
    Never felt a need to run the engine after an oil change. Cargo cult. :whistle:
    RCO likes this.
  9. wsalopek
    wsalopek Junior Member
    70
    Morro Bay, CA
    2015 Prius Plug-in
    Why would disengaging the traction control damage the transaxle? Many cars have a button that disengages the traction control at any time the driver desires.
  10. ChapmanF
    15,662
    Because the transaxle has powerful electric motors that develop large torque right away, and if a wheel breaks traction they can spin up to rotor-destroying speeds faster than you can react.
    The first-generation Prius had a "traction control" that was only there to protect the motors, and didn't do anything else that helped you with traction.
    Starting with Gen 2, the traction control can do the rest of the more useful things like applying the brake individually on the slipping wheel, so it is more deserving of the name "traction control". And the later generations have also continued to up the safe maximum motor rpm. But one function of the control is still to make sure the rotor magnets stay inside the case.
    In Gen 3 (maybe it started in Gen 2? not sure), there are two modes, distinguished by different numbers of go-pedal presses in the chicken dance. They separated out the run-engine-constantly and the disable-traction-control mode.
    The run-engine-constantly mode can be needed for some kinds of emission test. The TRAC-disable mode can be needed for speedo or dyno tests.
    The run-engine-constantly mode can be needed for some procedures that require you to get the engine all the way up to thermostat-open temperature or to fan-triggering temperature. I've used it for bleeding the cooling system after a coolant change. Haven't used it myself just for an oil change.
    There's a confusion in this thread back at post #4, somebody was confusing this maintenance mode (which runs the engine constantly) with a different thing entirely, getting the multifunction display to show some diag information.
    davecook89t likes this.
