Maintenance mode
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by StephenJ, Aug 28, 2017.
  1. StephenJ
    StephenJ Member
    226
    63
    Birmingham, AL
    Four Touring
    Can the car be driven in maintenance mode or can that damage any of the hybrid systems? Not sure if its for driving in or just idle. What's the low down on it?
    Thanks!
    Stephen
  2. dolj
    dolj Senior Member
    8,571
    4,354
    Wellington, New Zealand
    Inspection mode (as it is called) is not designed for driving, just running the ICE continuously while in the shop.
    You can potentially cause damage to the HSD driving in inspection mode.
    edthefox5 likes this.
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    yep thats what is says right on the MFD. DO NOT DRIVE.
    Inspection mode disables the traction system so over reving of MG2 is possible.
  4. valde3
    valde3 Senior Member
    2,002
    750
    Finland
    Like others said you shouldn’t drive in maintenance mode.
    But in slippery conditions sometimes you might have to. If there is steep, icy, and snowy hill that you have to start with little speed you might need to use maintenance mode to disable the traction control system. But with good winter tires you shouldn’t need to do this often. I’ve needed it less than once a year.
    But the most important thing in those conditions (in maintenance mode or not) is to remember to put the gear in neutral or reverse when you can’t get up the hill. Other vice when you start slipping backwards down the hill Prius wants to use the front wheels to stop it going down causing you to have no way to steer!
