Maintenance Needed Questions
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by fustion, Feb 17, 2018.
  1. fustion
    fustion Junior Member
    Antelope
    Hi All,
    I recently got my Dad's Prius and I took it to a nondealer repair place called TOS in Sacramento. They told me I needed to do some stuff which I have no idea if the Prius needs or not. They told me I should do a Shock/ Strut change, Fuel System Cleaning & PCV Value. I have 131000 miles in the car so I was wondering if you guys can let me know if these are usually done in a Prius.
    Thanks Guys :)
    #1 fustion, Feb 17, 2018
  2. Dxta
    Dxta Senior Member
    1,932
    767
    Lagos
    They can be done on a Prius, but as long as you don't have problems with the struts, no need.
    The blower fans, inverter and engine coolants, brake fluids, and perhaps the transmission fluid are what in my view should have being checked by the non dealer.
    fustion likes this.
  3. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    Shocks and struts age by use, if you drive harder, they age quicker, they certainly could be ready if I was driving, how sedate is your dad?
    If you want to do 'Fuel System Cleaning' blow $15 on a bottle of Techron every 100,000 miles.
    amazon.com/Chevron-65740-Techron-Concentrate-Cleaner/dp/B00092893E
    The PVC valve should have been changed at 120,000 miles, if it wasn't, it is time.
    [edit] I like Dxta's list, brake fluid ages with humidity, it will last longer in Phoenix than New Orleans.
    fustion likes this.
  4. fustion
    Antelope
    Hey Jimbo, this is what they are exactly doing on this fuel injection. I'm not positive if its the same as the $15 bottle.
  5. Dxta
    Dxta Senior Member
    1,932
    767
    Lagos
    If that's what they said they'd do, I think its right
    fustion likes this.
  6. fustion
    Antelope
    Would it be alright to show you guys what they are recommending to do? Just want an opinion on it and if the price is right.
  7. Dxta
    Dxta Senior Member
    1,932
    767
    Lagos
    Yeah, sure.
  8. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    The Prius reacts badly to throttle body cleaning, you can find a dozen threads here about owners who regret it.
    Throttle body doesn't work after cleaning | PriusChat
    Cleaning the intake manifold is useless, as a Prius blows air/fuel from the cylinders back into the intake tract, It always looks oily in there.
  9. Dxta
    Dxta Senior Member
    1,932
    767
    Lagos
    I think for the throttle assembly cleaning, if done well, I have never experienced any reactions with it.
    fustion likes this.
  10. fustion
    Antelope
    I have put the photos on top. They did recommend me the spark plugs but I already did them at 119.
    Thanks Guys!
  11. Dxta
    Dxta Senior Member
    1,932
    767
    Lagos
    That's cool
  12. Elektroingenieur
    2,515
    3,259
    Three Touring
    Here are a few thoughts, in addition to the excellent points others have made:
    • It’s reasonable to replace the automatic transmission (transaxle) fluid, but Toyota warns against substitutes for Genuine Toyota ATF WS fluid, like the proposed “ATF CASTROL SYN,” even if they are said to be compatible.
      Castrol’s data sheets for Transmax Full Synthetic Multi-Vehicle ATF and Transmax Import Multi-Vehicle ATF do not say either product is a suitable replacement for Toyota ATF WS. (The T-IV and JWS-3390 specifications that are listed apply only to older Toyota vehicles.)
      This has been discussed at tedious length in another thread, but note that Toyota doesn’t give a warning like this about engine oil, coolant, fuel, etc., for which it’s fine to use any product that meets the specifications in the Owner’s Manual.
    • It’s a bit odd to say “Check and adjust fluid level with scan tool”; according to Toyota’s Repair Manual, available by subscription to techinfo.toyota.com, the transaxle fluid level is checked by opening the filler plug and viewing the level inside, not with a scan tool. I suppose this might be something the shop’s estimating software prints for any car that doesn’t have a transmission dipstick.
    • For the transaxle filler and drain plugs and for the engine oil drain plug, the Repair Manual says new gaskets should be used each time the plugs are reinstalled. Those are missing from the proposed parts lists; make sure the shop uses them.
    • Changing the intake air filter is a good idea, but I wouldn’t pay $40 for labor to have it done, at least until you’ve watched the NutzAboutVolts video and decided that you couldn’t do the job yourself.
  13. bisco
    49,500
    couple more thoughts:
    do you have dads service records? it would be helpful to know what has been done, especially at the major 120k maintenance.
    if not, input the vin into the toyota owners website to see what has been done at the dealership.
    2) is TOS familiar with hybrids?
    3) is the car running fine and getting good mpg's?
    Mendel Leisk and NutzAboutBolts like this.
  14. fustion
    Antelope
    TOS is familiar with hybrids but the prius is only getting 43 42 unless im on the highway going 65 then ill get 46 47.
    Thanks!
  15. bisco
    49,500
    it's possible that everything is fine with those numbers.
  16. The Critic
    The Critic Resident Critic
    3,193
    2,321
    CA
    Couple things:
    1- The Prius Hybrid Transaxle Fluid is a drain and refill only. Most other Toyota models require using a scan tool to properly set the fluid level, but the Prius is not one of them. So, their quote is incorrect. I also suggest using ATF-WS only, but that is another debate altogether.
    2- They quoted you a decent sum to clean the K&N air filter that is in the car. I suggest getting rid of the K&N and installing a proper OE Toyota air filter for $15-$20.
    3- The Fuel System Cleaning is of questionable benefit and I would skip it. Your funds are better spent elsewhere.
    4- Same goes for the PCV valve replacement. They quoted both the hose and the valve. While it may not be unreasonable to consider replacing the PCV valve, I personally do not see the value of it. The labor charge is not unreasonable since the valve is a pain to access without removing the manifold.
    5- The charge (and need) for the brake fluid flush is reasonable. To do the service properly, you should be using the scan tool. I am aware that there is a way to do it without the scan tool, but it is dicey.
    6- The charge for the engine and inverter coolant replacements are awfully high.
    7- The shop quoted you a price to replace the front struts with pre-assembled KYB struts (includes new strut, generic mounting hardware and spring). Do not do this. The pre-assembled struts are built using junk generic hardware and the hardware will be problematic overtime. Replace only the strut, upper insulator and mount bearing (if-needed) using Genuine Toyota parts.
    I can do some of this work for you if you want, but I am not local.
    fustion and Raytheeagle like this.
  17. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,482
    Bay Area, California
    2019 Prius Prime
  18. Mendel Leisk
    38,728
    Trumping all of this: Toyota's admonition in the Owner's Manual, that using anything other than Toyota ATF WS could damage the transaxle. Oddly, that statement seems to invariably attract rebuttal like "yes, but what about such-and-such...". Arguably the most expensive component in the car, Toyota ATF WS readily available, not exhorbitantly priced: of course we'll consider/debate alternative fluids.
  19. The Critic
    3,193
    2,321
    CA
    Agreed. Then you have to ask - what about the aftermarket fluids that are made specifically (and only) for WS applications?
    ATF TYPE TLS-LV - Toyota, Lexus, Scion ATF | Idemitsu Lubricants
  20. Mendel Leisk
    38,728
    I mean, behind the scenes, the above guys might be making Toyota's ATF WS, who knows. I would wait, until the fluid is officially authorized by Toyota. And wonder in the interim, why that isn't the case.
