"Maintenance Reguired" light on at 4600 miles?
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Kensterfly, Dec 20, 2013.
  1. Kensterfly
    Kensterfly Junior Member
    95
    2013 Prius v wagon
    My bride's 2013 v5 is flashing "Maintenance Required" at a little over 4600 miles. Way too early for the recommended 10K oil change (though we will probably do the first change at 5K)
    What is it trying to tell us?
  2. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    5K is the standard "maintenance" point for routine inspection and tire rotation. the light will flash for a bit when you turn the car on after 4500, then be steady on at 5K.
  3. jdenenberg
    jdenenberg EE Professor
    3,953
    1,949
    Trumbull, CT
    2020 Prius
    LE AWD-e
    You can read how to reset the warning in your owner's manual. On my 2004 Prius you make sure that the Odometer is showing your total miles (not one of the trip miles), shut the Prius down and then hold down the ODO button (don't let go) while turning the Prius back on. The Odo then cycles through a countdown and when it shows your miles driven the reset is done (then let go of the Odo button :) ).
    JeffD
  4. drysider
    drysider Active Member
    823
    336
    Liberty Lake WA
    It is different for the GenIII's...check the manual. Mine is on page 403.
  5. Kensterfly
    95
    2013 Prius v wagon
    Thanks for the replies.
  6. rjparker
    rjparker Tu Humilde Sirviente
    10,481
    6,570
    Texas Hill Country
    The only service at 5k is the tire rotation. Take it to the dealer, they should do it free and the oil changes until 24k or 2 years, whichever comes first. They will also do a multi-point check free.
  7. schinia
    schinia Member
    162
    25
    cape carteret,nc
    my 2012 didn't ! only at 10,000 it comes on.
  8. JACoH
    JACoH Enjoying the mileage
    193
    40
    Oregon
    My 2012 "v" wagon maintenance light comes on every 5000 miles.
  9. JasonW
    JasonW Junior Member
    30
    Texas : Austin Area
    I just had to do mine today. Found a YouTube video dealing with it. On the v model (2012 in my case) this is how you do it:
    1) Make sure that the car is displaying the "A" trip odometer.
    2) Turn off car
    3) Hold down the mi/km button in the middle of the dash (keep it down)
    3) Push the power button twice (about 1/2 second between pushes) (no brake)
    The odometer will go blank and display all zeros and the digits will sequentially disappear. After the last zero disappears, release the mi/km button.
    The light is now reset for another 5k miles.
  10. orenji
    orenji Senior Member
    5,887
    3,488
    Prius C comes on every 5K miles.
