maintenance reminder- engine oil
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Dan Bond, Jun 11, 2019.
  1. Dan Bond
    Dan Bond New Member
    Galveston
    2018 Prius
    This warning pops up every start up. 2000 miles since last change. Level is fine. Local dealer is stumped. Any suggestions? upload_2019-6-11_10-31-8.png
    49,500
    welcome!
    how many miles on her?
    were they unable to reset it?
    what does the owners manual say?
  3. krmcg
    2,592
    2,390
    Whittier, CA
    The dealer probably forgot to reset it when the oil change was completed. There is a reset function buried in the settings menu...
  4. alanwagen
    alanwagen Member
    121
    79
    FORT WORTH
    2018 Prius
    are you sure that is not a notification from your phone? Turn off your bluteooth and see if it stops.
  5. alanclarkeau
    alanclarkeau Senior Member
    7,044
    7,584
    near Brisbane, Australia
    That's odd that it's on the Entertainment Unit - like mentioned above, try disconnecting your phone (or leave it home for a trip or 2).
    The only reminder mentioned in the 2016 USA Owner's Manual is in the main display, NOT the RADIO:
  6. Salamander_King
    Salamander_King Senior Member
    10,975
    8,868
    New England
    Did you try the "Do Not Tell Me Again" button on the screen???
    kithmo, krmcg and alanclarkeau like this.
  7. Dan Bond
    Dan Bond New Member
    Galveston
    2018 Prius
    The car has 48000 miles, 2000 since last oil change. I’ve reset the maintenance warning in the settings several times. The dealer did also. Tapped the “don’t tell me again” button several times, but the warning keeps coming back. The owners manual only talks about the main maintenance required warning. Turning off Bluetooth didn’t help.
    krmcg likes this.
  8. alanclarkeau
    7,044
    7,584
    I presume you've read this - and the next couple of pages:
    Raytheeagle likes this.
