maintenance required light
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by rivernet, Jun 21, 2004.
  1. rivernet
    rivernet New Member
    Lake Placid
    Does anybody know how to reset the maintenance required light? Thank you.
  2. jchu
    jchu New Member
    1,063
    Nampa, ID
    The instructions are hidden somewhere in the manual but I just did an oil change this weekend.
    To reset do as follows:
    1) Power down with car in ODO mode (as opposed to trip A / trip B
    2) While pressing and holding the ODO button under the MFD (Multi Function Display), hit the Power Button twice WITHOUT you foot on the brake. Do not press the button too fast or else the computer will not recognize the separate pushes. What you should see is a bunch of lines where the miles usually appear under the speedometer. One by one they will go out until after about 5 seconds the Odometer will show a bunch of zeros and the Maintenance Req'd light should also go out.
    3) Power Down and you are done
  3. rivernet
    rivernet New Member
    Lake Placid
    Thank you.
  4. jamarimutt
    jamarimutt New Member
    985
    It would be much easier if the navigation screen had a section for configuring basic functions which would allow you to do this plus several other things, like resetting the maintenance required light.
  5. jamarimutt
    985
    Oops, I meant to say like turning off the reverse beep.
