Maintenance Required light
Discussion in 'Gen 2 Prius Technical Discussion' started by michael1945, Jan 6, 2007.
  1. michael1945
    michael1945 New Member
    An independent garage changed the oil and filter. He was unable to turn off the warning light and followed the suggested procedure: How to turn off the "Maintenance Required" light
    Before turning the car on press and hold the trip meter button. Continue pressing it while you put your foot on the brake and hit the power button. Once the power is on, the odometer will show five dashes instead of numbers. Continue to press the trip meter until all the dashes go away. It didn't work. HELP!
  2. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
    <div class='quotetop'>QUOTE(michael1945 @ Jan 6 2007, 12:10 PM) [snapback]371824[/snapback]</div>
    You first must make sure that ODO/TRIP display is in the odometer mode, not trip A or B, before the car is turned off. Only then should you start the reset procedure which you outlined above.
  3. michael1945
    <div class='quotetop'>QUOTE(IsrAmeriPrius @ Jan 6 2007, 04:52 PM) [snapback]371845[/snapback]</div>
    I'll try that as I recall the odometer said trip A.
    Thank you for your help.
