Maintenance Required Ligth
Discussion in 'Gen 2 Prius Main Forum' started by maggieddd, Jul 27, 2006.
  1. maggieddd
    maggieddd Senior Member
    2,090
    Boston
    Usually when I am due for oil change usually 500 miles before, I get the light reminding me about it. I have 29,729 miles on my car and I do not get that "Maintenance Required" light. Anyone know what's up?
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    What was your exact mileage at your last oil change? It should come on (temporarily) 4500 miles after that, assuming the shop reset the maint. req. light for you at the time of the oil change. It will remain on constantly at 5000 miles.
  3. eagle33199
    eagle33199 Platinum Member
    5,122
    268
    2015 Prius v wagon
    Yeah, odds are you just had the previous change done at 25,300 or something... i know my last oil change was a couple of hundred miles off due to the timing between it and the 4th of july weekend :-p
  4. philwojo
    philwojo Member
    104
    Darien, IL (West Burbs of Chicago)
    <div class='quotetop'>QUOTE(maggieddd @ Jul 27 2006, 07:32 AM) [snapback]293084[/snapback]</div>
    Is there a way to reset that light if you do your own oil change? I know that is probably on the board somewhere, but thought I would ask since this post is current, if I don't get a reply I will obvioulsy start to search. I am at like 4,900 miles but already did my own oil change.
    thanks,
    Phil
  5. brandon
    brandon Member
    771
    Manhattan, KS
  6. philwojo
    philwojo Member
    104
    Thanks I just haven't had time to search yet for it I knew it was out there, darn people at work expecting me to do stuff!!
    phil
  7. maggieddd
    2,090
    Boston
    <div class='quotetop'>QUOTE(efusco @ Jul 27 2006, 09:39 AM) [snapback]293115[/snapback]</div>
    My last oil change was very close to 25,000 miles. The light was reset after the last oil change. It has been usually blinking every 4500 miles but it doesn't do that any more.
