Maintenance Required Warning Light Question
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by vinnysca, Jan 19, 2007.
  1. vinnysca
    vinnysca New Member
    200
    I have a 2006 Package 6 Prius with only 7900 miles. The only service I've had thus far was a scheduled dealership oilchange.
    I just recently noticed that when I start the car up, the maintenance required warning light blinks 5 times, then disappears completely. I don't recall noticing this before. Is this the norm? Has anyone else noticed this?
    Thank you.
    Vince. :D
  2. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
    <div class='quotetop'>QUOTE(vinny @ Jan 19 2007, 03:33 PM) [snapback]378019[/snapback]</div>
    The blinking on start up begins at the 4,500 miles mark after the Maintenance Required light was reset. At the 5,000 miles mark it will become solid and remain on until reset once again.
  3. Pinto Girl
    Pinto Girl New Member
    3,093
    350
    <div class='quotetop'>QUOTE(IsrAmeriPrius @ Jan 19 2007, 06:42 PM) [snapback]378023[/snapback]</div>
    Might I ask, does the car also keep track of months, as well as miles, and display the warning light at, say 5.5 months?
    I'm proud to say that I'm not going to get close to driving 5,000 miles in six months...
  4. mcbrunnhilde
    mcbrunnhilde Opera singin' Prius nut!
    619
    26
    <div class='quotetop'>QUOTE(Pinto Girl @ Jan 19 2007, 04:04 PM) [snapback]378030[/snapback]</div>
    Nope, it only tracks miles. It starts blinking at 4,500 miles, and then at 5,000 miles since the last reset, it stays on all the time.
  5. maggieddd
    maggieddd Senior Member
    2,090
    Boston
    <div class='quotetop'>QUOTE(mcbrunnhilde @ Jan 19 2007, 08:52 PM) [snapback]378076[/snapback]</div>
    anyone know if I can reset the light to blink close to even 5000 miles intervals again. Last time I forgot to reset the light so I drove with the light for like 400 miles so obviously my light blinks every 5000 miles from the time it was reset not when the oil was actually changed. I want it to blink at the right intervals again. Is that possible? Parheps I should just reset the light next time I change oil even though the light won't be on.
  6. jdenenberg
    jdenenberg EE Professor
    3,926
    1,923
    Trumbull, CT
    2020 Prius
    LE AWD-e
    <div class='quotetop'>QUOTE(maggieddd @ Jan 20 2007, 07:59 AM) [snapback]378208[/snapback]</div>
    Yes, you can reset the maintenance light at any time and it will then remind you 4500/5000 miles later.
    JeffD
  7. IsrAmeriPrius
    4,333
    Southern California
    The Navigation system has maintenance reminders that, when set, track by both miles and time.
  8. vinnysca
    vinnysca New Member
    200
    I tried resetting my maintenance reminders via the nav screen. Yet, the blinking warning light is still there. Is there another way to reset it?
    Vince.
  9. jburns
    jburns Senior Senior Member
    829
    111
    Archdale, NC
    <div class='quotetop'>QUOTE(vinny @ Jan 20 2007, 08:17 PM) [snapback]378437[/snapback]</div>
    It's in the manual but I'm not near my car at the moment. I think you hold down the ODO button while you power up and for a few seconds afterwards.
  10. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    same "problem" here. i'm putting extended mile sythetic oil in.. sure enough it turns on at 5k still.
    My car has close to 70k miles on it. I only use sythetic.
  11. dmckinstry
    dmckinstry New Member
    1,034
    Cheney, WA (Near Spokane)
    It should only start blinking at startup about 4500 miles after the last reset. At what mileage did you do the first oil change? Did you do it at 3400 miles instead of waiting for 5000 miles?
    Dave M.
  12. IsrAmeriPrius
    4,333
    Southern California
    <div class='quotetop'>QUOTE(vinny @ Jan 20 2007, 05:17 PM) [snapback]378437[/snapback]</div>
    The NAV maintenance reminders appear on the MFD screen and are independent of the dashboard maintenance required light.
  13. dmckinstry
    1,034
    Yep. The "magic" formula is on the bottom-right of page 130 and onto 131 of the 2006 Owner's Manual. That's in the section 2-5 of Operation of Instruments and Controls.
    I have an '05, so it's on a different page of my manual.
    Dave M.
