Maintenance requirement on 2005 Prius, 235k miles, garaged for 21 months?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by George N. Petrakakis, Mar 21, 2021.
  1. George N. Petrakakis
    George N. Petrakakis Junior Member
    What maintenance should be performed on a 2005 Prius with 235,000 miles, after being garaged for 21 months? Vehicle was not on blocks or jacks. Tires require replacement because of treadwear. Thank you in advance!
    51,674
    engine oil and filter should do it.
    fuel system might be gummed up. but i would try to start it before getting into a big project like that.
    probably need a 12v, and likely a new hybrid battery.
    George N. Petrakakis likes this.
  3. mr_guy_mann
    mr_guy_mann Senior Member
    4,029
    1,957
    NJ-USA
    Replace the12V battery just because. Check fluid levels then see what you have as far as HV battery goes. It would be a good idea to pump the gas out of the tank if possible- I have had old (dead) gas cause valves in the engine to stick open before.
    If the HV battery is bad then your options are limited. If it does start and run (then go buy a lottery ticket), plan on changing ALL fluids (engine oil and coolant, inverter coolant, trans fluid, brake fluid) , full engine tune up, inspecting brakes, testing cooling system and hoses, checking all computers for codes. And eventually replace the tires.
  4. George N. Petrakakis
    The 12v battery had been disconnected. Vehicle starts and runs ok. Oil change completed, changed engine air filter and all wiper blades, filled up the tank with regular unleaded, heat and A/C work.
  5. George N. Petrakakis
  6. bisco
    51,674
    congrats, all the best!(y)
