Maintenance Schedule Advice
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by KelliLynn, Nov 13, 2013.
  1. KelliLynn
    KelliLynn New Member
    Hi Everyone!
    Just bought a used 2005 with pretty decent maintenance records (about 76,000 miles). Need some advice on what intervals I should be changing fluids based on the following:
    PCV Valve - done at 49,229 miles
    Transmission Drain and Fill - done at 32,000 miles
    Throttle Body Cleaning - done at 65,000 miles
    Water Pump/Coolant - replaced under recall at 50,948 miles
    New tires (Pirelli at 65,000 miles (previous owner always swapped out snow tires every winter)
    Oil changes were done consistently
    Thanks!
  2. dorunron
    dorunron Senior Member
    3,318
    1,103
    Houston, TX
    Welcome to Prius Chat.
    It sounds like your car has been well maintained. I would follow the recommended service intervals that are in the owners manual. You can also log onto Toyota Owners Official Web Site: Service Coupons, Owner's Manuals, Service Scheduling And More and register the VIN of your Prius in your name there. Once you are signed up, you can get information concerning maintenance recommended, service records on your vehicle as well as record things you have done yourself. If you need a owners manual, you can obtain one there.
    Best of luck to you and again Welcome to Prius Chat.
  3. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
