Maintenance Schedule neeeded for 2015 Prius C
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by noname87, Jun 30, 2022.
  1. noname87
    noname87 Junior Member
    84
    NC
    My daughter purchased a 2015 Prius c. She has the manual but I can't find the schedule maintenance chart. I suspect that was in a different booklet which she didn't get. Does anyone know where I can download this?
    49,455
    toyota.com/owners
  3. PriusCamper
    PriusCamper Senior Member
    11,095
    4,515
    Pacific Northwest, USA
    If you tell us how many miles we can give you way more maintenance info than Toyota will...
  4. noname87
    84
    NC
    Car has 60,000 miles.
    I was surprised that they don't recommend changing the inverter coolant as they did with my 2008 Prius.
  5. PriusCamper
    11,095
    4,515
    Mostly just inspecting & testing everything... Checking all the systems for error codes, looking at hybrid battery health, 12v health, etc...
    Maybe change engine air filter if it's dirty and definitely change cabin air filter. Also good time for an oil change, tires rotated & pumped up. And a known problem with Prius C is a minor oil leak at the timing chain cover so you'll want to clean and inspect that area, as well as check all the bolts are tight so if you ever get a leak in that spot in the future you'll be able to accurately measure how minor the leak is. No need to fix this leak as long as it remains minor.
    No need to change spark plugs till 100K miles. If throttle body looks clean don't bother, but if it looks dirty then clean it and also clean Mass Air Flow (MAF) sensor. Also at some point in the lifespan of the car you'll want to change the trans fluid once, even though Toyota doesn't think its necessary, it will reduce wear slightly.
