Make my Prius QUIETER
Discussion in 'Gen 3 Prius Main Forum' started by Dave4Ed, Jun 17, 2016.
  1. Dave4Ed
    Dave4Ed Junior Member
    Does anyone have any ideas on how to make my Prius quieter. One item I saw years ago was a rubber insert that went into the wheel wells that blocked road noise. Do you know where they can be found. Better yet do you have any better ideas?
  2. BZzap!
    BZzap! Senior Member
    1,607
    878
    I was thinking that spraying the wheel wells with Rhino Bed liner coating might not be a bad idea. I wouldn't use a spray can but have it done in a shop that specializes in bed liners.
  3. maurices
    maurices Member
    128
    37
    Sartell, Minnesota
    I have done this, a slight improvement in road noise. I have also under coated the body with it, took off the under body panels. Sight improvement.
    52,393
    dynamat and the like. do under the carpeting, inside the doors and the hatch under the tyre. buy new tyres and spray the wheel wells. you'll have yourself a rolls royce.(y)
  5. scrappy
    scrappy Active Member
    125
    309
    Orange County, CA
    2014 Prius Plug-in
    There is no easy solution. Mass loaded vinyl married with closed cell foam is the only truly effective sound blocker that I know will work in vehicle application. Although there is some closed cell foam used in aircraft for heat and sound blocking that is somewhat effective.
    A little dynamat goes a long way to deaden reverberating body panels but it is not a sound blocker. Lining your car with something like dynamat only makes your car heavier and the dynamat guys richer.
    Lots of good info here: Sound Deadener Showdown | Your Vehicle Quiet
  6. RevRD
    RevRD Junior Member
    San Antonio
    Maybe good tires? Michelin MXM4s might do the trick?
  7. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    Ear plugs... J/K
    Raytheeagle likes this.
  8. bobzchemist
    bobzchemist Active Member
    507
    342
    Kennesaw, Georgia, USA
    I know that this stuff works in industrial settings. Not sure how you'd get it retail, though:
    Mascoat Sound Control-dB
  9. bkborgman
    bkborgman Junior Member
    I too am interested in making my Prius quieter as my commute to work often requires me to take highways / interstates when the surface level streets are clogged. Has anyone ever taken detailed measurements to narrow down the origin of the noise and how sound deadening material helps quiet things down?
  10. mikeuk
    mikeuk New Member
    uk
    I purchased a set of Dunlop sp blue response by far the quietest tyre I have had now concrete M50 is bearable we don't Need to turn the stereo up to drown the noise
  11. Kenny94945
    Kenny94945 Active Member
    858
    433
    Sausalito
    2016 Prius v wagon
    See post # 4 from Bisco.
    That is the answer.
    Biggest of the list would be to remove the seats and carpet and line the floor with Dynomat.
    Yet that will quiet the car.
    Have fun.
  12. Vman455
    Vman455 Senior Member
    539
    556
    The Middle
    Except, Dynamat isn't a good noise blocker--it's a vibration damping mat that stops panel resonance. To block noise, you need mass, and the most effective way to do that is with heavy, mass-loaded vinyl over a decoupler, usually closed-cell foam.
