Making a point
Discussion in 'Fred's House of Pancakes' started by Stevewoods, Aug 7, 2020.
  1. Stevewoods
    Stevewoods Senior Member
    663
    1,200
    Seattle, WA
    I usually avoid Facebook. I especially avoid any of the "quizzes, polls," etc., but a relative had posted the picture below and asked if anyone knew what it was -- of course, it was one of those "things" that are passed around the web, but surprised that pretty much no one knew what the photo depicted.
    I remember bringing my future wife to tears one Saturday as I supervised her setting up the device. Hey's she is sensitive.
    John321 and jerrymildred like this.
    52,390
    points
    i just sold all my facebook stock. zuck is going to rule the world someday
    make sure you have the mark of the beast
  3. ChapmanF
    18,546
    Always frustrated me that I would think I had it spot on, and then tightening the clamp screw would shift it.
    One car I had, there was an oblong hole in the base with teeth along the side, and a dimple it the mounting plate below it. You wouldn't need it very loose to adjust, because you could stick your Phillips screwdriver through the toothy hole into the dimple and twist, and adjust it that way.
  4. Leadfoot J. McCoalroller
    8,147
    7,646
    Pennsylvania
    2018 Prius c
    IIRC that was (or was functionally identical to) a standard feature of Robert Bosch distributors from the mid-60s onwards.
    I could set the points in my very first car with the thick top lid of a soda can. Not perfect, but close enough to get me back to a set of gauges.
  5. jerrymildred
    jerrymildred Senior Member
    11,517
    14,158
    Tampa, FL
    What's your "point?" :ROFLMAO:
    They were super easy to set on my old motorcycles once I discovered the trick of tuning an AM radio between stations.
    fotomoto likes this.
  6. Trollbait
    12,681
    I wouldn't say knowing what they are is a test of cognitive ability. Honor role school students today probably wouldn't recognize a slide rule.
    None of the cars I've owned had points.
  7. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    My first "big" motorcycle mod: converting a 77 Honda SuperSport to an electronic ignition. (y)
