Making fun at the Volt 230MPG.
Discussion in 'Fred's House of Pancakes' started by TheForce, Aug 25, 2009.
  1. TheForce
    3,461
    537
    Wheelersburg, Ohio
    I'm wanting to go to some car shows before it gets to cold and I want to make another display showing off my awesome 299MPG tank. I thought the best way I can do that and try to impress people was to copy and modify the Volt advertising campaign. I came up with two ideas. Which one do you think I should use for display? Or should I use both?
    The first one matches the original except I have 299 and Right Now! under the 299.
    The second one gives a little more information (still leaves out the most important info but so did GM) and is more of an eye grabber but still has the same theme.
  2. ibmindless
    ibmindless Member
    206
    I like the 2nd one best, but if you added "MPG" to the first, it might add the proper amount of detail for some folks. Then I'd agree you should display both. BTW, CONGRATULATIONS on your accomplishment! I assume you've documented the feat somewhere here on P-Chat?
  3. Richard_Simmons
    Richard_Simmons New Member
    2001 Prius
    I think..
  4. patsparks
    10,664
    567
    Adelaide South Australia
    I prefer [​IMG]
    The other has too much information. Put your web address on the bottom and hand out cards which have the URL on them so people can seek out more information.
  5. TonyPSchaefer
    14,816
    2,498
    66
    Far-North Chicagoland
    Did the Volt thing have "MPG" after the "230"? Is, then I would add it. If not, then I wouldn't. I think the point is to be exactly like their sign. There's a chance enough people would get the point.
  6. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    ya i would put the MPG instead of the "right now" part... what is your reason for putting that there? give me a good enough explanation and i might be willing to change my mind...
    hehehe
  7. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,999
    Fort Lee, NJ
    How about this?
    299 MPG in 2009
  8. eagle33199
    eagle33199 Platinum Member
    5,122
    268
    2015 Prius v wagon
    his reasoning... probably because the Volt isn't available yet, while the Prius has been around for over a decade!
  9. TheForce
    3,461
    537
    Wheelersburg, Ohio
    Well the ad campaign I found was the 230 with a date under it. Now that the date has passed I have found it with 230 and cheveyvolt.com under it. Thats it and nothing else. I dont have a short easy to remember URL to put under it so I put "Right Now!" to say you can get 299MPG RIGHT NOW! and dont have to wait for the volt to be released.
    I think I will use the first one as I think it will get people to ask more questions. If I use the second one people will just look at it and walk by. Thats what I think will happen anyway.
  10. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    ahh ic. ok. leave in the right now and wedge the MPG between em then
