Malorn is right about the 35mpg Prius!
Discussion in 'Gen 2 Prius Fuel Economy' started by micheal, Jan 6, 2006.
  1. micheal
    micheal I feel pretty, oh so pretty.
    842
    Lubbock, TX
    I got back from a trip about a week ago of driving from Denver CO to Evanston WY and only got 35 mpg in my Prius! How could this be?! How could I have fallen for the Toyota trap of this being a green car?
    Oh wait, here are some more details I should probably consider before trading in for a Buick. The trip was on I-25 and I-80 at 75 mph with 500 lbs of people and probably around 300 lbs of cargo. The kicker was that we were driving into a headwind/crosswind that gusted to 60+mph. For those familiar with the Interstates, even the signs straddling the interstate warned against heavy winds ahead and at some points cautioned light trailers to not continue on the road (Interestingly enough there was only one semi that been blown over). Even more interesting was that we were being followed the entire way by a Chevy Lumina with 500 lbss of people and around 300 lbs of cargo. The gas mileage for the Lumina- was.........21 mpg (from its usual 28mpg hwy). Both cars filled up prior to leaving Denver.
    So, under the same conditions, with the driver taken out of the equation (cruise control set at 75mph), the Prius had 67% better mileage than the Lumina. One can look at the % decline in the conditions and find the Prius even did slightly better in the overall decrease (25% decrease in Lumina to 22% in the Prius).
    That my fellow PCers, is the best apples to apples comparison I have come across yet. (Tongue in cheek, I will admit, but the situation did actually happen).
  2. Jack 06
    Jack 06 New Member
    2,556
    Winters, CA: Prius capital of US. 30 miles W of S
    Those northwesterlies between Denver and Evanston in the winter make for as bad driving (with snow) as you'll find. If you were even able to maintain 75 MPH, that's an accomplishment. Did the Prius meander all over the road? It'd be hard not to.
  3. micheal
    842
    Lubbock, TX
    You are right about that! One thing that we were very thankful for was that there was no snow. That would have been really bad! People in Texas don't believe me when I tell them that they actually have gates that they use to close the interstate.
    The meandering wasn't much fun, but it wasn't too bad, except when you went from being in an air pocket from a Semi to getting hit with the wind. It didn't seem to be much worse than the Lumina. I never got really close to hitting anyone or felt unsafe.
  4. GreenMachine
    GreenMachine New Member
    760
    Vermont, USA
    What tires are you running?
  5. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    I would bet that my son could get 35 mpg in any Prius any time any road any speed and he could do better than that I bet he could get 25.
  6. micheal
    842
    Lubbock, TX
    Right now we are running the stock Goodyear Integrity at 42 front and 40 rear. At almost 30K miles though, we are going to be getting some different tires.
  7. windstrings
    windstrings Certified Prius Breeder
    6,280
    378
    Central Texas
    Car dealers do lots of little short runs... usually the mileage stinks until someone buys it and really drives it!
  8. ken1784
    ken1784 SuperMID designer
    2,940
    1,365
    67
    Yokohama, JAPAN
    A lot of factors...
    - elevation change (uphill)
    - high speed
    - heavy headwind
    - heavy load (max is 845 lbs.)
    - cold weather
    Ken@Japan
  9. benighted
    benighted New Member
    530
    Westport, WA
    Max is 845 lbs.? I hauled at least that much in boat motor parts (Detroit 671 Crank case, flywheel , Cam, pistons, about everything except for the block) plus me and my Dad over 200 miles. It was sitting pretty low but it handled the weight just fine and still got 46 MPG.
  10. 2Hybrids
    2Hybrids New Member
    565
    Eustis, Florida
    I'm kinda surprised at this figure...sure thought it got less than that...
  11. windstrings
    6,280
    378
    Central Texas
    Thats good to know, I'm not sure of the real reason, but I can guess that since the atkinson ICE "engine" does not have low end torque and is dependent upone the electric at low ICE rpms for acceleration. Maybe with excessive weight they are concerned the electric will be overworked, I could see how at low speeds for prolonged periods of time may tend to overheat things and really kill efficiency.
    I'm guessing you were able to get up to full speed to help prevent that.
  12. malorn
    malorn Senior Member
    4,281
    59
    "Somewhere in Flyover Country"
    Another factot with the Lumina is that it is at least 7 years old and I am sure not in top driving condition(Tires, tune-up, fuel etc)
  13. naterprius
    naterprius Senior Member
    1,843
    True, it would have been nice to have a brand new Lumina to test against. But, I've noticed in my own testing that I always seem to get the same percentage of EPA MPG when changing cars but not changing other factors. My commute to work gives me the same percentage of EPA MPG in all three cars, 04 Prius, 00 Trooper, and 94 Camry. Hills, traffic, wind, speeds, my driving seem to affect me mileage equally on all three cars.
    Nate
  14. 2Hybrids
    2Hybrids New Member
    565
    Eustis, Florida
    Do you recall what they were rated when new?
  15. malorn
    4,281
    59
    29 or 30 on the highway. A better comparison would be if you drove a late nineties Camry in the same condition in fornt of the Lumina. I would bet you whatever you wanted the Lumina would get better mileage.
  16. EricGo
    EricGo New Member
    1,805
    Albuquerque, NM (SouthWest US)
    What would you guess it is good for all tuned up, malorn. 23 ?
  17. ken1784
    2,940
    1,365
    67
    Yokohama, JAPAN
    Have you ever read an owner's manual?
    Ken@Japan
  18. benighted
    530
    Westport, WA
    Yes, but my point is most small cars can carry much more than the owners manual states. If you drive it right.
  19. JackDodge
    JackDodge Gold Member
    2,366
    Bloomfield Hills, MI
    No he's not :rolleyes:
  20. malorn
    4,281
    59
    Ja :( ck, can't you give me even one moment of peace in the sun?
