Mann-Filter ProVent 100 model 3931070793 OCC
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by nate358, Jul 19, 2022.
  1. nate358
    nate358 Junior Member
    94
    Columbus, OH
    A few months back I did a ton of research and bought everything I thought I needed to move the PCV Valve to a more vertical location and an OCC I thought would be good off of Amazon. When I went to do it, the straight barb I was going put in place of the PCV valve had a much smaller shoulder.. PCV has a 22mm HEX and this Barb was only 17mm HEX. I didn't feel comfortable with that. The OCC while way bigger than I needed to get has one of those brass filters that apparently clog and I've read reports that style of OCC is only 20% efficient.
    So I went back to the drawing board. I'm going to install an OEM Toyota PCV valve at the factory location. (I originally bought a replacement PCV that was aftermarket and the barb is slightly smaller than OEM another lesson learned).
    I ran across the Mann-Filter Provent 200 that states it's 95% efficient. Now we are talking! However, it is gigantic and has tons of knockoffs on Amazon. But the smallest Provent 100 could work. Saying these are oil catch cans is a little misleading... I would say they are oil and air separators, but I'm going to attach a tube that will hold the oil until I need to empty it. These are specifically designed for diesel engines. The smaller Provent 100 appear to be 80%-85% efficient which sounds pretty amazing to me. There are 4 models to choose from in the Provent 100 line...Basically 2 locations of the inlet and either a bypass valve or a pressure relief valve. I'm going with the one that has the inlet to the right and has a bypass valve (part# 3931070793). I'm not really sure which valve style would work best for our engine so if you know... Let me know.
    I found some awesome information and prices from dieselfiltersonline.com
    I even called them asking for some information on the 2 valve styles and he said he could send me a 22 page pdf here.... https://www.republic-mfg.com/images/Provent.pdf
    Shipped it came to $113.10, which after doing a head gasket job... Seems not too bad and hopefully, I won't have to do that anytime soon.
    I'm going to take some pics, post the installation, and outcome here so if it turns out a winner.... Others can use it as a resource. Screenshot_20220719-145928.jpeg
    #1 nate358, Jul 19, 2022
    StarCaller likes this.
  2. Tombukt2
    Tombukt2 Senior Member
    8,926
    1,553
    Durham NC
    See these on large equipment alot.
  3. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    What material is the medium that separates/filters the oil vapor out of the air made out of?
    There are stainless steel mesh filter mediums available for some of the Provent style separators out there.
    Also, have you decided where you are going to put it?
  4. nate358
    94
    Columbus, OH
    Wow, that came fast! Like Amazon Prime fast! Haha
    I'm not sure what the filter is made of... It isn't metal. I believe all the knock off 200 series use metal filter material. Somewhere I read the metal isn't as efficient as the name brand filters. I will take a picture of the filter when I figure out what allen key is needed to take it out. Unlike the 200 series that needs no tools to get the filter out, the 100 series had 4 screws that need removed. I believe they are metric because none of my Allen keys are fitting.
    Seriously fast shipping though.. Only 2 days from when I ordered it and I did the cheapest shipping rate! IMG_20220721_143123__01.jpeg IMG_20220721_143111__01.jpeg IMG_20220721_143106__01.jpeg
  5. ASRDogman
    ASRDogman Senior Member
    6,062
    3,255
    Are you going to hang it off the side of the Prius? It's huge! But then it is for a diesel! (y):)
  6. xliderider
    7,869
    3,116
    Honolulu, HI
    Yeah, that's pretty big. What size hoses are the inlet/outlet, 3/4 or 5/8 inch?
  7. xliderider
    7,869
    3,116
    Honolulu, HI
  8. Grit
    Grit Senior Member
    6,141
    4,054
    Wilkes Land
    :ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO:
  9. nate358
    94
    Columbus, OH
  10. xliderider
    7,869
    3,116
    Honolulu, HI
  11. nate358
    94
    Columbus, OH
    I found the correct size of the screws on top are 3mm Allen. Here are some pics of the interior and comparison to the original OCC I was going to install.
    I still don't understand where the by-pass is. I see 2 valves, one on the top and one on the side, which I believe come on all series 100 models. Maybe the bypass is considered the bottom where the oil collects and can either go back to the oil pan or in my situation, a line with a ball valve on the end for the oil to be disposed of when I do oil changes.
    You can see this Provent is quite shorter than what I was originally putting in, but thicker around.
    I'm going to go plan where it's going to go and I'll report back. IMG_20220722_135445__01.jpeg IMG_20220722_135502__01.jpeg IMG_20220722_143713.jpeg IMG_20220722_140054.jpeg IMG_20220722_140059.jpeg IMG_20220722_140120.jpeg IMG_20220722_140234.jpeg IMG_20220722_140242.jpeg IMG_20220722_140330.jpeg IMG_20220722_140346.jpeg
  12. xliderider
    7,869
    3,116
    Honolulu, HI
    You should use some kind of container to collect the oil that goes to the bottom outlet. Otherwise, if you don't drain it in a timely manner, the oil will back up over the filter element.
    There doesn't appear to be much room for oil to collect below the filter element in that cone shaped area above the outlet.
    Foxglove likes this.
  13. nate358
    94
    Columbus, OH
    I did a test with the 1/2" drain line to see how much it holds in comparison to this oversized OCC. The drain line would need to be 8.5 feet long to equal the holding volume of this OCC. I would say most OCCs everyone is installing are about half that size... So about 4.25 feet of drain line would equal the holding capacity of the standard OCC. IMG_20220723_210712.jpeg
  14. nate358
    94
    Columbus, OH
    I think this is where I'm going to put it... Right over the coolant bottle. IMG_20220723_215655.jpeg IMG_20220723_215559.jpeg IMG_20220723_215541.jpeg
  15. nate358
    94
    Columbus, OH
  16. mr_guy_mann
    mr_guy_mann Senior Member
    3,434
    1,493
    NJ-USA
    While you know that filter is for a diesel engine, you don't realize that it's designed to go between the crankcase breather port and the air intake duct. Oil that's separated goes out the bottom port back to a fitting into the oil pan.
    Plumb this into the PCV and the bottom port will have vacuum on it. And IDK what will happen if the filter is put under vacuum.
    Also, you need quite a bit of volume or have to empty it often in winter. Cold weather causes moisture in crankcase vapors to condense out in the OCC. I have a OCC with about 8 oz capacity, and at the first oil change in Feb (I use a 5k interval), the OCC was completely full of water.
    #16 mr_guy_mann, Jul 24, 2022
  17. nate358
    94
    Columbus, OH
  18. nate358
    94
    Columbus, OH
    Okay, here it is all plumbed up. PCV out goes to the Provent intake on the bottom... Vacuum line goes to the top port. It's a tight fit, but I was still able to fill the coolant. The last photo is with the hood closed. It looks like the Provent unit is touching the hood as well as the top line when closed.
    I used 5ft of 3/8" hose from the PCV valve to a 3/8" to 3/4" barbed fitting then 3/4" hose to the Provent. From the Provent out to another 3/4" to 3/8" barbed fitting... About 6ft of 3/8" hose to a 90 degree 3/8" to 3/8" barbed fitting and then cut the stock hose in half and attached it to the intake manifold.
    The drain port is just over 4ft long. It has about the same capacity as a normal OCC and I'll be able to see when it needs drained just by opening the hood. I ran it down behind the engine and zip tied it just below the transmission drain port.
    I ran the engine in maintenance mode last night for 42 min. It was the first time starting the engine since doing a new head gasket, new water pump and thermostat, valve job, and cleaned the ERG cooler, valve, intake manifold, & throttle body. All new coolant in both systems. It's only taken me since early May... So about 2.5 months. Sigh. Good news... No trouble codes came up! IMG_20220724_023744.jpeg IMG_20220724_023832.jpeg IMG_20220724_034504.jpeg IMG_20220724_023901.jpeg IMG_20220724_034411.jpeg
    SFO likes this.
  19. xliderider
    7,869
    3,116
    Honolulu, HI
    I hope everything works out for you, but that is a whole lot of tubing in that setup.
    I'm thinking that a lot of oil will be condensing on the inner walls of the tubing and all that liquid oil will back up down low, near the PCV valve, because that is the lowest point of the setup before getting to the filter.
    That's one of the reasons why I relocated my PCV valve to the OCC intake (highest point in the setup) when I put my OCC in a location near your setup (between the engine coolant reservoir and the engine). My hose runs are shorter too, because I routed my hoses between the engine and the intake manifold with a heat sleeve around them.
    #19 xliderider, Jul 24, 2022
    Bill Norton likes this.
  20. nate358
    94
    Columbus, OH
    I was going to move my PCV valve too but I couldn't find anything to put at the stock location. What did you put in its place?
