Manuals from techinfo.toyota.com
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by gbrehm, Feb 12, 2006.
  1. gbrehm
    gbrehm New Member
    36
    Springfield, VA (Northern VA)
    Snowed in Northern VA, I decided to checkout techinfo.
    Paid my $10.
    I've tried a couple ways to use Adobe to bulk download the site but have been unable to. Maybe they made some changes? I've read other posts on the subject and think I followed them. I tried File > Create PDF > From Web page and Advanced > Web Capture > Append Web Page...
    I get:
    No Input File Page Data http://techinfo.toyota.com/ileaf/06toyrm/0...rmsrc/priussrc/
    I've updated Acrobat. I've tested it on other sites.
    hmmm
    Anybody with recent techinfo success?
    Thanks!
    gb
  2. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    i paid my niece $25 to download each file individually. she did a great job. created a file structure and every thing.
  3. jbarnhart
    jbarnhart New Member
    629
    Santa Clara, CA
  4. priusenvy
    priusenvy Senior Member
    1,765
    Silicon Valley, CA
    You have to create an HTML file containing the URLs to all of the PDFs first, and then do "Append all links on page". I've alread posted instructions on how to do this, you can find them with a search.
  5. gbrehm
    gbrehm New Member
    36
    Well, maybe I just can't handle this....
    I *think* I read your posts on this topic.
    I just went back and reread them and played around a little with it.
    Using your example I created an html file with this in it.:
    "aaa
    aaa"
    Opened the file in Adobe and clicked "Append all links on page" and got the same error.
    I am going for 06 files so I was only using your example as a test.
    When I manually download an 06 file I get a filename/path of
    "http://techinfo.toyota.com/ileaf/06toyrm/06toypdf/06rmsrc/priussrc/00100110.pdf"
    Maybe:
    They changed the structure?
    I'm too stupid for this?
    or
    I'm real close, maybe you can push me over the edge?
    Thanks!
    gb
  6. priusenvy
    1,765
    Silicon Valley, CA
    I gave instructions on how to generate the paths to the files:
    "2) is simple to do by just viewing the frame source for the document list, and comparing it to the full URL to any one of the PDFs (I had to do this in Internet Explorer)."
    It sounds like things have moved around, but if you can just view the frame source, and get the list of PDFs, and then construct absolute URLs, you should be all set.
  7. husve
    husve New Member
    I have tried to do the same thing, but I did not successfully download the files by using adobe and get the same error message. It looks like that adobe acorbat 7.0 can not pass the security check even I know the detail file location of 06 Prius.
    For the repair maunal, the search function only showed 250 documents in the maximum, but if you go into submenu, you will find there are more than 250.
    Finally, I just download 90% of total files by clicking each file in one day.
  8. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    You're not stupid, the TIS interface is.
    http://techno-fandom.org/~hobbit/cars/toyota-tis-sucks.txt
    The 250 search-results limit is the biggest obstacle. If you work
    around that by getting smaller chunks, you can generate a full
    HTML index and preserve the directory structure -- this is important
    because there are lots of relative [e.g. ../../../file/path] links
    inside the PDFS. Once you've got that, "wget" the whole thing in
    bulk.
    I think that as of '06 the structure has changed a bit; a slightly
    shallower dir structure and the longer, more numeric and less
    meaningful filenames. And a lot of the relative links broke. I
    found this to be true when I grabbed the '06 Highlander hybrid
    stuff; haven't tried for '06 prius yet. Using that site gives me
    hives. The only way I could manage to log in on it was to frontend
    an IE box with a logging proxy, and grab the cookies out of its
    log to plug into "wget" later. Their support people basically tell
    you that unless you're running IE, you lose. Even recent firefox
    with all the bells-n-whistles enabled couldn't deal with it.
    _H*
  9. gbrehm
    gbrehm New Member
    36
    Thanks everyone, for your replies.
    It beat me, I manually downloaded everything while I was working thru this yesterday.
    DaveinOlyWA, great idea, I thought about getting my kids to do it but they went snowboarding with their aunt....
    jbarnhart, I tried wget but gave up. I was using the Windows version, it probably would have been easier using a *nix version but I wasn't up for that yesterday....
    by the way, look at hobbit's wonderful link, apparently he was able to use wget.
    priusenvy, thanks for trying to help, in the end I decided it was beyond me...
    husve, I feel your pain...
    unfortunately I think us mortals are resigned to this until Toyota follows hobbit's suggestions..
    hobbit, thanks for your kind words and the link. It was helpful and insightful. I wonder if the obfuscation isn't intentional though, just about has to be, no? I thought they had just added that perl wrapper, I see from your link it was always there.
    Thanks again!
    gb
  10. priusenvy
    1,765
    Silicon Valley, CA
    I've confirmed that there are problems logging into the Toyota site with Acrobat 7, but Acrobat 6 still works. And I was able to use the web capture feature and "append all links on page" to download 250 PDF files at once and combine them into a single document. However, as someone else pointed out, there are more than 250 documents that need to be downloaded for at least one of the manuals. As long as you can come up with an efficient way to create the complete list of documents, downloading with Acrobat can save you a lot of time. I didn't investigate any further on how to build the complete document list. So all I can confirm is that the first 250 documents per manual are easy using Acrobat 6.
  11. z80
    z80 Junior Member
    23
    2014 Prius c
    I
    Hello!
    I understand that the latest post here was 12 years ago and today is Oct 13 2018. But still may I ask how does techinfo at toyota at com look exactly? I need a few particular things. One of which is locate Prius C transmission fill plug location. Will I be able to do that for those $20 fee within 2 days allowed?
    Thank you!
  12. ChapmanF
    15,876
  13. z80
    z80 Junior Member
    23
    2014 Prius c
    I
    Thank you so much!
