Map and Dome light
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by gs7371, Aug 2, 2019.
  1. gs7371
    gs7371 New Member
    calif
    (2015 prius pulg in) map and dome light don't work. i have replaced the map consul, same problem.need some help!
    51,139
    welcome!
    bulb, fuse, switch?
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,137
    Tampa, FL
    Fuse would be my guess, assuming the rocker or slider switch is in the "door" position and not "off."
    51,139
    for the life of me, i don't understand how you can post 'help!' on friday, and not return the call by monday
  5. jerrymildred
    11,517
    14,137
    Tampa, FL
    Me neither, but it's pretty common. o_O
