Map compartment door replacement
Discussion in 'Gen 2 Prius Accessories & Modifications' started by McKeeius, Feb 16, 2010.
  1. McKeeius
    McKeeius New Member
    56
    Redwood City, CA
    I recently disassembled most of the dash to get to my head unit and stock stereo. I have an aftermarket unit installed in the compartment beneath the stock stereo what I am calling the 'map compartment' the one with the tinted hinged door on it.
    Well in the process i completely got that door off and a hinge came off, with a spring as well. Now I am lost on how to put it all back together? Any clues? Any guides?
    The guides for head unit installation just show how to take the entire casing off, and not the specific door and hinge piece.:confused:
  2. KCobby
    KCobby Member
    229
    74
    NYC area
    Sorry to hear about the door. Not sure I know how to help exactly, but perhaps if you also post some pics, someone else might at least be able to take a stab at it. Any pics?
  3. McKeeius
    McKeeius New Member
    56
    Redwood City, CA
    FWIW I was able to fix the dam door, what happened is I got a little reckless trying to take out the head unit, mfd, and compartment and just started unscrewing every screw I could find, which led to the door falling off and the spring popping out.
    The retracting action of the door is held together by a tension spring and is MAJOR pain in the butt to figure out how to pop it back in there, you have to load the spring it was really not fun. Just use care when unscrewing things around the head unit to be sure not to unscrew the hinges holding the door on there.
  4. don_chuwish
    don_chuwish Well Seasoned Member
    816
    182
    Southern Oregon
    <whew> glad to hear you got it sorted out and thanks for sharing the tip.
    - D
  5. cooterpls
    cooterpls New Member
    Pennsylvania
    Made an account just to say: my little spring popped off and I had a very hard time getting it back together. You have to remove the little hinges and untension the spring to replace the door, which I was doing cause mine was broken. To retension the spring I replaced the whole door back in it's spot, put the hinge pieces on and screwed it all together leaving the spring in place but not hooked or tensioned on anything. Tighten all the screws on both sides and then use needle nose pliers to hook the short side of the spring on it's corresponding hook on the little hinge piece. the other spring arm will fall into place on its own. Leave the door fully closed while you do this. Hope it helps someone else in 10 years.
