Map Dark Mode
Discussion in 'Prime Audio, Electronics, and Infotainment' started by Qmo, Jul 15, 2017.
  1. Qmo
    Qmo Member
    61
    52
    Sunnyvale, CA
    I remember there was dark mode for the 11". I've tried settings, display and turned on/off Day Mode but it didn't make any difference. Any idea?
  2. Tideland Prius
    16,621
    Make sure your IP (the two MIDs) setting isn't set at MAX brightness while your headlights are on and you're in a dark area.
    Qmo and dalcon95 like this.
  3. Prius from Dad
    Prius from Dad Senior Member
    724
    1,116
    Toms River, NJ USA
    There is a brightness level here that you need to take it one notch lower than max.
    Qmo likes this.
  4. Qmo
    Qmo Member
    61
    52
    Sunnyvale, CA
    Prius from Dad likes this.
  5. DavidA
    2,348
    1,823
    Chicago western burbs
    There is also a day setting in the display settings. Correctly set, the map isn't just dimmer when the lights are on, it is reversed with the proper black background ala the Gen3 when the headlights were on..
    Qmo likes this.
  6. Gaëtan Lafrance
    101
    77
    Montréal, Québec
    Technology
    Sorry but what is the ''IP (the two MIDs)'' ?
    Thanks
  7. Tideland Prius
    16,621
    Les deux écrans de 4,2 pouces dans l'habitacle.
    IP = instrument panel.
    MID = Multi-Information Display (On PriusChat, we use MID to refer to the screens in the instrument panel and MFD [Multi-Function Display] to the touchscreen display.)
    #7 Tideland Prius, Jul 25, 2017
    Gaëtan Lafrance likes this.
  8. Gaëtan Lafrance
    101
    77
    Montréal, Québec
    Technology
    Merci pour l'information.
    J'ai résolu le problème.
  9. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    Then you're using it wrong.
    The MID is only the one on the right on the instrument panel. The one on the left is called the "Main display".
