March Volt numbers are in - 2,289
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by hill, Apr 3, 2012.
  1. hill
    8,985
  2. spwolf
    spwolf Senior Member
    3,156
    440
    Eastern Europe
  3. drinnovation
    drinnovation EREV for EVER!
    2,027
    586
    65
    CO
  4. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Ahem, wassup with Leaf at 500 something sales here?
    it was 400 something last month. Word is some dealers have 5 in stock.
    Last October, San Leandro Nissan had 3 Leafs in stock for delivery.
    ... I was surprised in a bad way.
  5. JeffHastings
    JeffHastings Member
    223
    79
    Whippany, NJ
    GOOD news. Guess the uptake in gas prices and the recent heavy ad campaign did the trick for the Volt. It may just be here to stay!
  6. telmo744
    telmo744 HSD fanatic
    2,181
    769
    Portugal
    Congrats to GM...their way of building a green car finally is proving positive to the market. That helps the environment also, because in many states/countries EV can really reduce CO2 emissions!
  7. Rybold
    Rybold globally warmed member
    2,760
    322
    Southern California
    I used to see a Volt about once a month. Now, I see about 2-3 Volts each week. SLOWLY, they ARE increasing in population.
  8. Flying White Dutchman
    4,376
    313
    is it a virus?
    no ok for real better a volt then a ...... big truck
    less nOx, cleaner air, less cancer
  9. hill
    8,985
    . . . therein lies the irony. Nation wide, some dealers do have a few, while many dealers across the country are told they can't get one yet, and it'll be over a month until they can.
  10. bisco
    52,578
    pure ev will take longer as it limits peoples range and they have to decide whether to own an extra car or drive another household members car when going a long distance, etc. i foresee a slow start but dramatic growth when more charging infrastructure is available and batteries improve and word of mouth gets around from early adopters.
  11. drinnovation
    2,027
    586
    65
    CO
    It is unclear what is the cause but there are many that are saying it is a supply issue. Demand in Japan is also very high and with the Yen doing badly it is more profitable to sell them at home there in the US.
    My local dealers have none, I could not even test drive on without driving > 50miles. cars .com only shows 728 in the US. Combine that with a 16weeks ordering process and sales will continue to be slow.
    Maybe some dealers in CA have them, but there is still clearly a limited supply nationwide.
    On the other-hand, range anxiety is real, and even in a 2 car family it means you must take the other car for long trips. For many, that other car is less gas efficient than an Volt (and definitely less gas efficient than a Pip), so if one is going to pay for a EV, there is PiP, Volt as alternatives that could actually use LESS fuel overall than a BEV.
  12. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    Having announced the heat pump, I'd expect some buyers will sit on their hands anyway and wait for a TN 2013 model.
    Not particularly likely though on the Volt. If a family can ride in the Volt they can ride in a Prius and have more luggage space. Basically it would require "needing" an SUV/minivan and then for the solo driver to need to make long trips out of BEV range. But if you can swap BEV and large guzzler on some days, why do you need the large guzzler?
  13. drinnovation
    2,027
    586
    65
    CO
    I though the point of the heat pump is so you don't have to sit on your hands to say warm..
    (Sorry could not resist. yeah I can see that as upgrade worth waiting for)
  14. Skoorbmax
    Skoorbmax Senior Member
    2,641
    265
    Western NY
    A good bump. I know this isn't a Leaf thread, but as it's already been mentioned, what has happened to Nissan? Are they not making enough or nobody wants one? I still have yet to see a Leaf IRL. I see Volts from time to time.
  15. Keiichi
    Keiichi Active Member
    808
    79
    Goleta
    When I last looked at my small town area, the Chevy Dealer here had at least 3. That was about a month ago. They looked like they were the 2011 models, the ones prior to the NHTA concerns.
  16. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    I just came back from driving my mother to the doctors for a nosebleed that would not stop (over half hour). (btw, this can be common in elderly. It's from inside of nose that's too dry, low humidity. Saline and Vaseline spread inside nose can prevent it) ...
    On the way, I thought ... I wouldn't want an electric car that's not charged up enough to get to doctors and there is an urgent need to go. This could be buried in the conscience of many individuals ... never know when an emergency could happen and you need a vehicle that be fueled and go far quickly.
  17. Keiichi
    808
    79
    Goleta
    Which isn't a problem for the Volt given it has that gas ICE range extender. Although there is a small problem with EVs I just remembered with my time at UCSB that one person mentioned... Forgetting to unplug the charging cord before driving off, which can happen, especially if it was an emergency.
  18. essaunders
    essaunders Member
    195
    NH
    I have a LEAF. I don't worry about the "hospital scenario" because I either a) have a prius in the garage too or (more likely) b) will call an ambulance. Everything is also tempered by the fact I haven't yet run the LEAF under 45% charge and there are several hospitals within 10 miles. As long as the LEAF hasn't displayed the first low battery warning I can get to the hospital (if I choose to drive).
    The modern plugin cars are all interlocked to prevent driving while plugged in.
    Really, this is just another example of the mindset we've got to change. The need to have 4-wheel drive and high ground clearance "just in case" got us SUVs!
    Now, if you regularly need to drive in deep snow and/or off road - get a real SUV. If you regularly need to drive to the doctor's office on no notice after a day commuting, sure, skip all cars that don't have the range of commute + doctors_drive.
  19. UsedToLoveCars
    UsedToLoveCars Active Member
    448
    102
    same here in northern california.
  20. Jeff N
    Jeff N The answer is 0042
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    This can't happen with the newer plugin cars -- they won't switch out of "Park" if the J1772 cord is still plugged into the car.
