Mars Perseverance
Discussion in 'Environmental Discussion' started by iplug, Feb 18, 2021.
  1. iplug
    iplug Senior Member
    2,455
    1,703
    Rocklin, CA
  2. ETC(SS)
    6,544
    Gotta love the fact that Perseverance appears on the environmental sub-forum (because it's nuclear powered?) of a Prius sub-forum!
    Does the fact that it uses an RTG to charge a Lithium-Ion battery pack make it a 'hybrid'? :D
  3. wjtracy
    wjtracy Senior Member
    11,321
    3,590
    Northern VA (NoVA)
    The actual videos from the spacecraft are cool of the landing process.
    Damn we have to live 10 years to get the rocks back...I have to eat my Wheaties and live the good life in hopes to make it.
  4. Mendel Leisk
    38,662
  5. wjtracy
    11,321
    3,590
    Northern VA (NoVA)
    Had my scope on it Oct thru Nov due to close approach...lost it now it is tinier.
  6. PA Prius
    PA Prius Active Member
    754
    241
    SE Pennsylvania
    Maybe here on a car site, since rumor is that the first contact Perseverance received after landing was a call inquiring about its extended warranty.
    bwilson4web likes this.
  7. AzusaPrius
    AzusaPrius Senior Member
    1,859
    812
  8. ETC(SS)
    6,544
    I spent too many years under water to want to fly several months for the privilege on living under ground on Mars.
    Unless they noodle out how to generate a magnetopshere on Mars, the 'scenery' on Mars is going to be fairly uninteresting.....
    People sometimes ask me if I've ever been under the the Artic ice pack, and if so what it was like.
    I tell them that it's exactly like being on the equator or anywhere else in the ocean, and it looks like the inside of a submarine. :D
    iplug and bwilson4web like this.
  9. bwilson4web
    15,513
    Just to add:
    • 0.095 psi - Mars atmospheric pressure
    • 14.7 psi - Earth atmospheric pressure
    • ~154 difference
    Given the earth 0{2} ratio is about 20%, we could with a 100% oxygen level:
    • 2.94 psi - 100% Earth atmospheric pressure
    • ~31 difference
    The pressure difference means the 'suit' would have to be substantial, close to a vacuum suit ... the interior of a shallow water submarine.
    Personally, I would want an inner mesh of kevlar for pressure with an outer layer of reflective layers. The idea is to keep the 'cold' out and the 'warm' in. But there remains a ballistics problem.
    If (when) a meteor hits Mars and reaches the surface (likely), there will be a substantial outflow from the crater that spreads planet wide. With any reasonable Mars surface material density, these particle will easily pierce the suit and occupant.
    #9 bwilson4web, Feb 27, 2021
