Marvels Mystery Oil in engine?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by hec24, Oct 24, 2019.
  1. hec24
    hec24 New Member
    Has anyone ever put Marvels Mystery Oil in their engine? Notice any difference in mpg or horsepower?
    51,142
    i think some have, if you can find the threads, but i don't recall any confirming positive results.
    but for every product, their are a few true believers
    scona likes this.
  3. ETC(SS)
    6,955
    If it increases MPG or Horsepower then why don't they put it in the crankcase at the factory?
  4. Grit
    Grit Senior Member
    6,450
    4,186
    Wilkes Land
    If anything, it will only restore hp and or mpgs lost.
  5. audiodave
    audiodave Active Member
    798
    269
    US
    Been using it for almost a year. Seems to give couple miles extra a gallon. Same trip mostly freeway gave me 47mpg without and 50mpg with it. It's inexpensive to try.
    Can't say any difference in power.
    2004 with 255,000 miles and a 3 year old rebuilt battery.
  6. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,798
    2017 Prius c
    MMO is just a VERY thin oil and has some limited solvent properties.
    It is NOT appropriate to use in a new engine because it would do nothing worth while.
    It might tend to loosen stuck rings in an old engine......might.
    I used it once in an old pickup truck poured slowly down the intake and it had a DRAMATIC affect on oil usage.
    But that vehicle was over 30 years old and had near to 100K miles.
    Jim Swart likes this.
  7. frodoz737
    frodoz737 Top Wrench
    4,534
    2,438
    33
    Snake Oil.
    xerox6135 likes this.
  8. bisco
    51,142
    my father swore by it. he put that $h!^ on everything
  9. ASRDogman
    ASRDogman Senior Member
    7,233
    3,774
    If you change your oil as you should and use synthetic as you should it probably be of minimal help. Can't hurt though.
    As started above it could help keep the rings clean.
    I use it in the fuel tank every 5 or 6 tanks and it helps keep the injectors clean.
    I used it a lot on my van I could tell the difference. Minor mpg improvement possibly, but my city driving was 16-18 mpg,
    and highway was 20-25, so it was hard to really tell. But I could feel it when accelerating and at idle, it was smoother.
    That's when I knew it was time to use it.
    But results may very. :)
  10. sam spade 2
    7,035
    2,798
    2017 Prius c
    Actually it CAN hurt. If the overall viscosity of the oil goes BELOW the minimum required.
    AND MMO was not designed nor intended to "keep injectors clean".
    There are other products that ARE designed for that: Techron for instance.
    Any kind of oil in the gas will tend to increase carbon deposits in the combustion chambers too.
  11. ETC(SS)
    6,955
    I'm just trying to realize my lifelong dream of appearing in @Grit 's signature.....
    RMB, Raytheeagle, SFO and 2 others like this.
  12. Ed Beaty
    Ed Beaty Active Member
    334
    311
    Salt Lake City
    "I'm just trying to realize my lifelong dream of appearing in @Grit 's signature....."
    A truly worthy endeavor! ;)
  13. ASRDogman
    7,233
    3,774
    Well, I have only been using it on my van for 250,000 so I may not be accurate.
    And a few hundred thousand miles on 4 or 5 other vehicles since the early 80's.
    Since for the Prius they call for 0-20, it's hard to believe 8 ounces in 4.5 quarts are going to hurt it.
    But what do I know?
    I just know that when I use it when the idle starts getting rough and slight hesitation on acceleration,
    at 1/4-1/2 tank it clear up after putting in the fuel.
    Again, results may very per use per vehicle.
    #13 ASRDogman, Oct 25, 2019
  14. Rmay635703
    Rmay635703 Senior Member
    2,647
    1,670
    Somewhere in Wisconsin
    2013 Chevy Volt
    A start would be being allowed to see his profile page.
    ah the inner circle
