Massive Coolant Leak!!! Please help. (Now $4,000 Engine Repair!!!). Fixed! (Post #48)
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Priski, Sep 26, 2023.
  1. Priski
    Priski Junior Member
    34
    New Jersey
    Currently, no coolant is leaking to the oil. I have checked and the oil color is normal, not milk chocolate. Just got back from a 1700 mile road trip and my coolant is back below the 'low' fill line. Before I left, I filled the coolant tank up. Do you guys think a coolant hose has a leak somewhere?
    Also, yesterday it took 10-15 minutes for my heater to start working. It sounded like the heater ed it don't turn on for 7 minutes than within 3 minutes hot air blasted out. I heard coolant and the heater work together, I do not know how LOL.
    52,399
    is there a puddle where you park?
  3. Priski
    34
    New Jersey
    Let me go check, I think I would need to drive it a but to find out. I do not think so though. What do you think of the picture with the possible dried coolant?
    52,399
    it could be coolant. i depends on how fast you're losing it. at a very slow rate, it might dry or evaporate before puddling. or if it only leaks while running, you could be leaving it on the road.
    any way to get it up on a lift and remove the aero panels?
  5. Priski
    34
    New Jersey
    Not really unfortunately. I took more pictures of where I see coolant on the engine and I tested out the heater and it did not blow hot at all which is unusual.
  6. Classic Car Guy
    Classic Car Guy Active Member
    466
    127
    Northwest, USA
    you can got to a parts store like o' reily and have them loan you a radiator / coolant pressure test so you know where its leaking or a pressure drop.
    A bad thermostat with delay opening will do that too. I had my share of those when I was young. Never again.
  7. Priski
    34
    New Jersey
    Here are the images
  8. Priski
    34
    New Jersey
    Thanks, I will investigate this.
  9. rjparker
    rjparker Tu Humilde Sirviente
    10,536
    6,617
    Texas Hill Country
    Codes or temp lights? Clearly you have low coolant probably lower than you think with air or combustion gasses in the coolant system. This is obvious when the heater is delayed. Excessive temp will cause the reservoir cap to release pressure and spray coolant.
    Codes would tell you if you had a pump problem or excessive temp causing the cap release. Other possibilities are thermostat or clogging sealer previously used in the system.
    A Prius head gasket fail will burn the coolant in the cylinder and replace some of the coolant with combustion gas.
    Act quickly or the engine will be ruined.
    Brian1954 likes this.
  10. Priski
    34
    New Jersey
    Thanks TJ, I have the car parked and will not be driving it until it is fixed. I will start by figuring out how to run it with a code reader. Right now my best guess is the thermostat is broken. As of right now I do not think the headgasket has broken yet because the car does not rough idle. How would I check excessive heat and the cap opening? And is it the cap on top of the coolant reservoir?
  11. Priski
    34
    New Jersey
    As of right now, no codes and no temp like. However the temp like the small red lines right? Have came on intermittently then disappeared.
  12. rjparker
    10,536
    6,617
    Texas Hill Country
    Thermostats rarely fail these days. The water pump does fail but normally will code. You must have codes if the temp lights come up. Typical auto supply scanners are rarely good on hybrids. The check engine, car with ! sign or the triangle light are typical.
    Temp lights intermittently means it hit about 240f or higher on a car that typically runs 190-205f, Too hot. Air in the system can cause erratic readings. Bad pump or failed radiator fans are possible.
    These cars won’t rough idle with a hg except on occasional cold starts. Otherwise the coolant can be consumed without a misfire. Often without codes. If hg fails were not so common I might focus elsewhere but they are very common on these engines. New design head gasket, pistons and rings were used by 2015. You and I have earlier models.
  13. Priski
    34
    New Jersey
    What are some signs of the water pump starting to fail and or radiator fan? How to I get air out of the system? If it is a head gasket, won't my oil turn into the chocolatey color? Thank you for the help, your advanced insight.
  14. rjparker
    10,536
    6,617
    Texas Hill Country
    Pump causes overheating and temp lights. You should see coolant flow into the reservoir when warmed up.
    To remove air I would probably drain the coolant and measure. Typically you will get about five quarts which can be reused if it does not have 70k miles on it already. Distilled water at $1 a gallon can be used to completely fill it until you or a hybrid experienced mechanic (recommended) figure it out. Run engine when filled in Maintenance Mode with cap off to release air. Watch coolant temp with scanner. At 190 or higher you can use a flashlight to observe coolant flowing into the reservoir from the bottom hose. That would indicate an open thermostat and functional pump. Don’t do this without monitoring temp since there is a problem. Once the air quits bubbling out fill again, cap and drive with scanner monitoring temps.
    Radiator fans should come on with the AC. But they are two speed so the best test is with a bidirectional scanner to command them on. When it’s really hot >205f or so the fans should come on without AC.
    No coolant in the oil on these engines! It burns the coolant which then goes out the exhaust. Bad bad end stage hg leaks will blow white smoke when the engine is rev’d up. You have to be back there to see it, but this is new engine time late stage. Normal hg leaks are not observable as white smoke because it is so slow to leak into the cylinder, typically when cold.
    A borescope test under pressure is the definitive hg test. See my post from Sunday.
    #14 rjparker, Sep 26, 2023
  15. Mendel Leisk
    41,925
    Has the miles been mentioned?
  16. Priski
    34
    New Jersey
    178k unfortunately in head gasket territory. Crossing my fingers it is something else!
    Okay, I will do some of these test and let you know what I have found.
    #16 Priski, Sep 26, 2023
  17. Mendel Leisk
    41,925
    Good you've read enough to know that. Exhaust Gas Recirculation components (including intake manifold) ever cleaned?
  18. Priski
    34
    New Jersey
    Like the EGR, yes last year it was cleaned out.
  19. Tombukt2
    Tombukt2 Senior Member
    13,459
    2,420
    Durham NC
    Not likely to be anything else but head gasket seepage and if you're going to take it apart to fix that and there's any oil consumption going on you may want to go ahead and figure the extra time to pull the lower girdle and pan off the bottom of the engine undo the rod caps and push the pistons through the top of the cylinder with the head off and out and fit the new tension rings for oil control and I guess new compression rings since you have the mess out I don't know that the compression rings have changed but that dainty little oil control ring from what I understand are certainly changed. If you ever looked at another non Atkinson cycle normal engine you generally haven't seen oil control rings like these these things look like something from cosplay jewelry If I would have seen this in the junkyard apart I would have never bought a Gen 3 just for that. But my time in the salvage industry ended in like 2002 or 3 right it's the first Prius was being released to the market or the second generation rather. I had seen a few of the first generation sedans come in I really like them but they look very cheap and like they would not go the distance. The minute I saw the generation 2 I remember when my friend first got one it was like $30,000 I knew that car was kind of special It was very different from the first generation it carried with it in his genetics the lift back from old TE37 and 57 Corollas and other things that Toyota people would recognize pretty instantly. Very much unlike the generation 3.
  20. rjparker
    10,536
    6,617
    Texas Hill Country
    You need new pistons and rings. The pistons were changed as well.
    Also the op needs to have the head sent to a machine shop for an inspection and rebuild.
    By the time you do this much it makes better sense to install a professionally rebuilt engine if years of ownership is the plan.
