Master Brake Cylinder Failure
Discussion in 'Gen 3 Prius Technical Discussion' started by Hoffy, May 22, 2010.
  1. Hoffy
    Hoffy New Member
    Toronto
    Hi All,
    Although I've lurked regularly, this is my first post. I'll apologize ahead of time if I've missed a thread about this, but I couldn't find one.
    Anyway, was on the way for a trip with my wife and three dogs and waiting in line for a coffee at Timmy's. The dash lit up like a Christmas tree and indicated "Check PCS System". Drove to my dealer and they were good about getting a tech to quickly check the codes. Since I had to get my wife to Ottawa that afternoon, about 400 KMs they quickly arranged a loaner and we were on the way.
    I came back after the trip the next day and the service manager indicates it needs a new master brake cylinder. Brake fluid is leaking internally and the new one has to come from California. Looks like I'll be driving the loaner for a week or so.
    The surprise is that the part is $6000 per the Service Manager, all covered by warranty, thank goodness!:eek:
    My questions are;
    - has anyone seen this before?
    - if this happens after warranty, it's way too expensive!
    - makes me wonder if I have to trade the car before the 60k KM warranty is up. (this part is only covered by regular warranty, it's not part of the drive train warranty or the hybrid warranty)
    Thanks for any replies.
    Cheers.
    Hoffy.
  2. bwilson4web
    15,400
    This is new but considering the cost, this sounds like the assembly that holds all of the valves. If you can, perhaps ask for the failed part?
    Used parts from warranty work are not always given to the owner but asking is OK. If nothing else, ask for the part number and see if you can make photos of the part.
  3. timo27
    timo27 Member
    316
    52
    Baltimore, MD
    Sounds like an awful lot to me (my only BMC failure experience was on my Mom's Saab and that was about US$1K--maybe more complex due to the hybrid features?) Sounds like Bob's advice is good--if they won't give you (access to) the part, you could at least call around to other dealers asking quotes for the exact work completed, and maybe compare w/ same from an independent shop.
    At least it was under warranty! Good luck.
    ~T
    slawek likes this.
  4. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    Given that the car is essentially brand new and the failure is significant
    -- not catastrophic in that there was no accident/collision -- I would
    expect that Toyota would want to inspect/tear-down the master brake
    cylinder for quality control purposes.
    So, is there really any chance of getting the part?
  5. Patrick Wong
    18,199
    6,464
    Close to zero chance. The OP is not paying for the part, so the dealer will either discard it or else return to Toyota (if Toyota cares).
    My guess is that the failed part is the brake actuator assembly.
    MikeDee likes this.
  6. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    Agreed.
    Many manufacturers require dealers to keep parts replaced under warranty for a certain period of time, to allow the manufacturer to audit warranty repair work.
  7. adamace1
    adamace1 Senior Member
    1,403
    191
    Charlotte, NC
    Toyota will want the part.
  8. cossie1600
    cossie1600 Active Member
    898
    92
    CT
    DOesnt autozone sell one for like $40 bux?
  9. Mike Dimmick
    Mike Dimmick Active Member
    963
    247
    Reading, UK
    The Brake Master Cylinder is the component that turns your pressure on the brake pedal to hydraulic pressure in two pipes. On a conventional car (no Electronic Brake-force Distribution) that pressure then pushes the piston in the wheel cylinder, which presses the pad against the disc/drum, with each brake line handling two wheel cylinders.
    In the Prius the lines normally go to a pressure sensor and a 'stroke simulator', a cylinder in which a piston simply pushes against some springs, to provide the feel of braking. There's a unit - the actuator - full of hydraulic valves that control the flow of brake fluid from a high-pressure reservoir (accumulator) to the wheel cylinders, and pressure sensors that measure what's going on.
    The third part is the Skid Control ECU which controls the valves according to the pressure sensors measuring the driver's input and the sensors measuring the brake force applied.
    Champion ToyotaWorld doesn't yet have parts listings for the 2010 Prius, but for a 2009 Prius the costs are: master cylinder $114.56, actuator (listed as 'modulator valve') $1,412.03, ECU (listed as 'control module' under 'stability control') $1,112.05. Those are discount prices, the MSRP is considerably more.
    I don't have a 2010 manual, but for Gen 2 it was necessary to remove the inverter to replace the actuator. TSB BR001-07 (Brake Actuator Noise) gives a time of 4.4 hours to replace the actuator. On the 2010 car the inverter (Power Control Unit) is smaller and further toward the front of the car so it may now be out of the way. You also had to remove the inverter to replace the master cylinder.
  10. Airbalancer
    Airbalancer Active Member
    892
    73
    Cobourg, On, Canada
    But the price is in CDN so the $6gs could be on the low side :D
    Parts fault, at times, and it is no one fault, it getting fix , you have loaner so all is good
  11. Hoffy
    Hoffy New Member
    Toronto
    Well I got the repaired car back today. A week to get parts and replace. I spoke with the tech (good guy, has been the only person to work on my car since new), he indicated that a head office contact said only one other 2010 Prius in Canada has had this failure so far. The assembly mentioned above came as a unit, including the brake control computer. For 2010's they have to remove the windshield wipers, the plastic assembly below that and a metal tray below that to to get at the whole assembly (new procedure for 2010's), although the same assembly is used on the 2008/2009. Took him about 6 hours of solid work with some hair pulling and meticulous following of repair procedure. I'm a happy camper though because he took great care and volunteered to test drive with me because he knew I'm very particular about the car.
    Also, they made an error in the earlier pricing. Now they indicate the whole assembly was about $3500. Better but still expensive.
    The part number on my warranty invoice for the assembly is 47050-47060.
    Thanks for all the comments posted. Muchly appreciated!
    27,000 KMs and counting.
    Hoffy.
  12. Downrange
    Downrange Active Member
    353
    181
    2024 Prius Prime
    SE
    Regardless, that sounds like a ridiculous price for that part, and I have to say this sets up a significant doubt in my mind about the longer term cost efficiency of owning a Prius. Hopefully, this is just one small data point and not part of a larger trend toward the parts manufacturers taking advantage of the complexity of this car to gouge customers.
    Here's something else I've been thinking about - if parts are that expensive, what happens when one of these has a fairly serious front end collision? All those cooling radiators and the complex electronics, etc. I can imagine the insurance companies may well be totaling these cars for damage that, in a more common vehicle, would be easily covered within the insurance envelope.
    Worrisome, to say the least. We hit a lot of deer down this way, and I can imagine such a collision doing damage to the tune of at least 10-12K, which would pretty much total a Prius that wasn't right out of the showroom...
  13. qbee42
    qbee42 My other car is a boat
    18,058
    3,073
    Northern Michigan
    Prius have proven very cost effective over the long term. You shouldn't read too much into a major warranty replacement. In this sort of situation Toyota will often replace an entire assembly to make sure the job is done quickly and without complications. For a non-warranty repair you often can replace or repair only a subsection, or use a rebuilt or salvaged part.
    Tom
  14. Downrange
    353
    181
    2024 Prius Prime
    SE
    OK, Tom, thanks, that's somewhat reassuring. I will search through here on accident threads to see how Priuses fare in the "totaled out" department. When I put my aftermarket horns in, I could not help but notice that engine compartment has a lot of pricey-looking apparatus up front...
  15. qbee42
    18,058
    3,073
    Northern Michigan
    That it does. It's one of the paradoxes of high tech electronics: it's not likely to fail, but when it does, it can be expensive. The average cost of ownership is very low, but if you are one of the unlucky ones, a repair can be expensive. It's like being hit with a piece of falling space junk: it's not likely to happen, but if your the one that gets hit, you are totally screwed.
    Tom
  16. bwilson4web
    15,400
    Adding to Tom's comment:
    In the USA we lose about 3% of all vehicles per year. A substantial number wind up with a significant number of usable parts that can repair other Prius. For example, AutoBeYours has been in business for years rebuilding salvaged NHW20s. The irony is if someone wanted to buy a plug-in Prius, AutoBeYours has been selling them for at least a year if not longer.
    One other aspect are the growing number of 'Do It Yourself' folks whose curiosity leads them to figuring out how these vehicles work. Often we learn more from what fails than from parts that never get 'opened up.'
  17. tedjohnson
    tedjohnson Member
    347
    72
    Greenfield MA
    That price is totally ridiculous.... $6,000 is a quarter of the cars total new cost. For a brake master cylinder? If the cost of replacements part is that high, who would take a chance on buying such a car with a 3 year, 36,000 mile warranty?
    sumus likes this.
  18. KenzoTH
    KenzoTH Member
    70
    38
    Rhode Island
    I am also concerned about the cost of such a part post warranty, but happy to hear the warning system works- for your sake and all who own a gen III.
  19. Legrand
    Legrand New Member
    AL
    I JUST had this fixed in my car.
    I got the car on the 30th of May, and it was in the shop 6 days later.
    It has been there since...until today.
    They had a guy fly in to fix it and also 3 guys from Toyota corporate to come and see it.
    I didnt have any alarms go off, just a loud creaking sound from the brake pedal when depressed or released.
    MikeDee likes this.
  20. Legrand
    Legrand New Member
    AL
    Hopefully everyone has GAP insurance.
