Master Cylinder Questions
Discussion in 'Gen 3 Prius Technical Discussion' started by Frontporch, Oct 20, 2024.
  1. Frontporch
    Frontporch Active Member
    494
    107
    Nj
    Just picked up a 2012 Prius after owning several 2nd gen Priuses. It wasn’t until I was driving home that I realized what that cycling hum was. Duh
    it is currently cycling every 5-10 seconds so I assume it’s overdue
    is there any option to exercise the master cylinder using tech stream? My gen2 had an ABS light on when I bought it and I was able to turn that off after going through some diagnostic process that had all the valves firing. I would probably flush the fluid first
    When it comes time to replace parts is there a way to know which part needs replacement. I assume the pump outlives the Master cylinder
    is tech stream used after install? Hopefully the version I have used on the gen2 works here as well
    thanks all!
  2. Frontporch
    494
    107
    Nj
    I am going to start answering my question. Please feel free to respond.
    Looks like the techstream is not as much the issue here as the miniVCI cable. I am lucky that I don't need immediate use of my Prius, so I will probably see if I can go through the brake bleed and recalibrate procedure, if nothing else, to test that my setup works before ordering any parts. If it doesn't work, I can buy and return amazon cables that don't work and keep the one that does. BTW, if replacing brake fluid and bleeding stops the pump from cycling, I will wait to do anything else.
    I also believe that the master cylinder (connected to pedal) is the culprit and not the unit with the pumps/storage. sorry I don't have the jargon here. I will pickup a replacement from an online dealership and replace only the MC. (~$600). I can always go back in and replace the second component. These are expensive enough to make it worth the extra legwork.
  3. Frontporch
    494
    107
    Nj
    I abandoned using techstream and went with the Topdon Topscan. Thanks to a video on YouTube I knew what to expect. It went off well up until the end when it was going to do the linear calibration. I wasn’t in ACC mode and didn’t get a second chance to do that. Will look into it more tomorrow and see if I can do that without the bleed procedure
